Recent SPTPC Series 2 Cable Re-termination quick summary
-I purchased a single pair of Iconoclast SPTPC Series 2 speaker cable years ago.
-I purchased a second set and ran them parallel after hearing Galen’s presentation at AXPONA and reading an Iconoclasts review by Douglas Schroeder.
-Doubling the Iconoclasts speaker cable, doubles the well-reviewed positive sound attributes of the cable, plus adds greater bass weight.
-This meant to each speaker and amplifier binding post there were 2 pairs of spades, one with and without a Cardas spade to banana adapter.
-I knew all the extra spade and adapter hardware likely effected the sound.
-However, I did not know how much.
-I delayed having them re-terminated because I did not want to spend the money or be without music.
-Finally I decided late this summer to send the cables back to Blue Jeans and have them re-terminated. So I could properly run parallel cables.
-In doing so I eliminated the hardware shown in the picture, plus 4 pairs of spades and 4 additional Cardas Connectors not shown.
-You can see the Iconoclast re-terminated cables in the photo.
-With the re-terminated cables the first thing I noticed was there was greater musical cohesion.
-The instruments and vocals just flowed together more naturally, were more consistent and synchronized.
-A new problem then revealed itself.
-There was a negative softening, dullness to the immediate left and right of the center phantom image within the soundstage.
-I discovered the culprit was the foam padding my super tweeters rested on, that was slightly wider and forward than the tweeters.
-I had been using the foam padding for years to angle the super tweeters down as they sat on top of my speakers.
-Now the greater resolution allowed me to hear just how much the foam was softening and effecting the side and back waves of the music.
-I was surprised I had never perceived this softening before and how detrimental it was.
-I then changed out the foam wedge material, adjusted the super tweeter position to lock in proper phase, and BINGO.
-There is now greater resolution, separation, leading edge and decay, bass note distinction, and the music is more uniformly and evenly spread across a wider and deeper soundstage.
-The change is hard to quantify, but it is noticeable.
-It was a worthwhile investment having the Iconoclast cables doubled and terminated into one left and right pair.
-Both are things I would recommend others consider.
-As always it was nice working with Blue Jeans Cable and Jeff does great work.
