Best music streamer, Expert recommendations to choose
I am looking for the best music streamer as i recently upgraded my home audio setup and wanted a dedicated device to stream high-quality music instead of relying on my phone or laptop all the time. i have been experiencing connection drops, inconsistent sound quality, and interruptions when notifications come in, which really takes away from the listening experience. i went through reviews from trusted sources like What Hi-Fi?, TechRadar, and Audio Science Review and after comparing many options these two kept coming up as the top choices:
Auris Blume Duo HiFi Bluetooth 5.0 Music TV Transmitter & Receiver Long Range Wireless Adapter | Audiophile DAC, LDAC, aptX HD/LL, Display, Battery & Optical AUX Output Input for Stereo Amplifier Car
https://www.amazon.com/Auris-BluetoothB0CQ2YMQR9serrttg3443555bbb
Audioengine B1 5.3 Bluetooth Receiver for Older Classic Stereo Speakers and Sound Systems - Long Range HiFi Adaptive Wireless Up to 32 Bit Audio Music Streamer
https://www.amazon.com/Audioengine-B1-PB00MHTGZR4?b3445555gttttserrgbb
however, i am having trouble deciding which one would be better for me and i would love to get your expert advice and hoping maybe some audiophiles, sound engineers, or experienced home audio users on this forum can also share their advice.
i usually listen to lossless music, stream from multiple services, and care a lot about sound quality and ease of use, so any suggestions or advice would be appreciated.
Thanks in advance
Warning, you may just be beginning.
First, be aware of streamer vs dac. Some boxes have both. Up the ladder, they get separated.
I began with Bluesound Node, then the NeoStream, then Topping DAC with NeoStream used only as streamer, then to much better DAC and the PSA AirLens. Drip, drip, drip. Now earlier stage components sleep in boxes. No doubt, the future will take more steps/drips. Others here have already taken such steps, bigger and bigger as they evolve.
Thus, be ware of accumulating overtaken components. Likely, it will happen. So the question, how much money do you want to eventually save if you purchase a box now to be surpassed, leaving the original box dormant (ie, an expense in the closet).
Good night, and good luck. (great movie and Broadway play) Oh, what fun it is.
If the advanced features and screen don’t matter to you, the WiiM Pro Plus is a bargain. I pair it with a Schiit Modi 2 Multibit DAC with excellent results for background and casual listening. For critical and deeper listening sessions, I’ve focused my audio dollars on CD and vinyl playback. Enjoy!
I alternate often between NOS and over sampling mode on the Schiit. I like them both and I can never really decide which one I like best. A slight nod to NOS mode most of time.
Depending on (1) your current budget and (2) where you expect to be with streaming in future years the BlueSound Node Nano is an easy recommendation. Had a BlueSound Node and it was trouble free, easy to use and reliable app which is paramount IMO. Sold it here, more like gave it away as irt was as new, for $175 shipped. My wife then changed her mind and deciced she did want a streaming stereo for her condo/office, but no multiple boxes, and simple speakers. We stopped in at Madison’s University Audio. She selected the NAD C379 and a pair of bookshelf Sonus Faber Lumina II speakers. Her ears, her choice. She loves the simplicity of the BlueSound app, with easy access to Qobuz and Tune-in. Now broken in she is most pleased, especially after I replaced the complimentary zip cord with a $2,800 pair of Nirvana SL speaker cables. Everything just locked in. A nice budget streaming system.
So my recommendation, get the BlueSound Node Nano for the sound, simplicity and the BlueSound OS app.
Down the road reach for a Grimm MU2, :laughing:
That depends on the product. The MU2, for instance, is a streamer, DAC and preamp all in one, and sounds ridiculously fantastic, and is something to aspire to.
The PMG streamer/DAC is also on it’s way, and is also something to look forward to.
I have had many many streamers as my journey progressed. I have found until you spend a buttload of money they sound similar. I have found 3 tiers.
  1. the ones you listed above are in that tier. High value, high functionality. my guess is you will not “hear” a difference.
  2. spend $1200-2000 and you get that next level of clarity and detail in your music. You may even get LESS features in that price than the lower. I know sounds weird but they are built for quality sound not bells and whistles.
  3. $3000-5000 tier.. sounds better bells and whistles come back.
I know this is short and sweet and much more info behind it. And Yes there is higher tier(s), but I have not yet reach them (MU2, Wolf, and others.) so I am not one who can advise on those.
Ima stay out of this one.
(See my thread “The Best USB Cable under $15”)
I have tried the three-tier (and higher) journey, and Brian is spot on. It really depends on your end goal here. If you just use streamer to find new music or use it for background music, you do not need to spend much. However, if your desire is to enjoy high-quality music, you should just start on the third tier. The streamer alone is not enough to do the job, the implementation of noise filtering and cabling all matters.
For example, I did not reach a level that was deemed satisfying to me until I moved to a Lumin U2, plus a bunch of filtering devices before it. Unfortunately, my main listening enjoyment was still from discs because CD was still better. So, I did not stop there. :money_mouth_face:
:index_pointing_up:
I’ve been immersed in the BS ecosystem for 7 years and overall am very satisfied.
As others have mentioned, it’s doubtful there will be any meaningful difference in sound quality. It and everything else in the system would have to move up in the food chain first.
Useful features and I/O will be more important.
Good luck!
Does anyone have any experience with the Rockna Wavelight Server (a/k/a the WLS)?
It looks like it has a lot of potential to me:
Trying to figure out if/how it would work as an endpoint with Roon and/or JRMC or only as a server (if that makes any sense).
From the website:
“The WLS has the ability to let you choose from a variety of server software and audio services including Roon, MPD, LMS and so on. There are many use scenarios, the device can be used as core , or can be used as renderer or endpoint .”
Looks promising.
It is designed to have as much as 16TB of internal storage. I wonder if it sounds as good as it looks. I2S out is an option so it might work with PSA DACs.
In addition to the sound quality, as I noted above, I would like to know more about how well it plays with music rendering software like Roon, JRMC etc.
Maybe someone here owns one or has had a chance to play with one…?
Cheers.
Following up:
“Today we have a similar debate over this anyone know what this is class anyone? Anyone anyone seen this before…”
[Channeling Ben Stein in “Ferris Bueller’s Day Off”]
Looks hard to get and zilch pricing info based on the US and UK dealers’ websites. This should please those special forum members over on the MU2 & Steath cable threads… :slight_smile: But only if it costs $20k or more!
I dunno…
This caught my eye on Audiogon:
https://www.audiogon.com/listings/lisbefe0-rockna-audio-wavelight-server-wls-10tb-storage-i2s-dsd512-upsampling-music-servers-docks
10TB/$3,200 used. One of the reasons for my request for insights from the Hi-Fi mavens here.
Many, many people I know are very happy with Eversolo Streamers…
Good find! I figured it was going to be unobtainium. I was wrong (happens a lot).
One more bump…
Anyone familiar with this kit…?:
anyone
There’s always the three box Innuos Nazaré ($50,000).
“Just a bit outside” – of my budget that is.
Nice kit.
I recently asked a friend if there $40k preamp is $40k remarkable. The answer I got was “Well… “ .
Thanks for your advice really appreciate you taking the time to share your experience.
With the help of your reply, I decided to go ahead and buy the WiiM Ultra Music Streamer and I am happy to say it is working great.The setup was smooth and the sound quality has definitely exceeded my expectations for the price. It fits my needs perfectly especially for casual and background listening.
Thanks so much for helping me make the right choice.
Best regards,
Moe
