Am going to be ordering longer columns for my Quadraspire rack to fit my BHK 250 on the bottom rack, am wondering if the 10" columns leave enough space or if I should go with the 12.75" columns. If not familiar, the Quadraspire rack is open on all sides.
Go for the 12.75" columns as the 10" one will only give you slightly more than an inch of top clearance. I always put mine on a stand in front of the rack to counteract the heat they generate.
thanks - appreciate it - it does get hot but read that they were intended to
Yes they getting hotter than a pure SS amplifier by nature but I wouldn’t push it by constricting the air flow over the top.
