patentpending said OK guys, here's my first post about the BHK monos!Patentpending,I have to be honest, however. It didn’t take me more than a couple of hours of initial listening before I became impatient enough to roll the gold lion tubes with some NOS Telefunken E88CC tubes that I’ve had here waiting for the amplifiers that I bought from Kevin at Upscale Audio (FYI at Telefunken E88CC / 6922 – Upscale Audio). I had read several reviews about these tubes from a variety of sources, and thought that they’d be good to try.
For someone that is as addicted to tube rolling as I am, and probably will try a few different tubes, swapping the tubes was a very easy proposition. The design of the monoblocks makes their access very straightforward using just a phillips screwdriver to unlatch the small metal covering. I found that the tube sockets in the monoblocks appeared to be very well made. The tubes easily came out, and the E88CC tubes went in. To my ears, this was a very noticeable improvement in sound quality (I can not overemphasize this, but take my opinion for what it is worth). So pleased as I was with the improvement, I went back to some initial listening.
I bought some of the Telefunken tubes from Kevin 5 months ago in anticipation for the BHK but haven’t put them in yet. To my horror I’d discovered a guy at JacMusic ( E88CC Telefunken NOS, or used tubes and recently updated at HALL OF SHAME, PICTURES OF FAKE TUBES ) who also bought “NOS” tubes from eastern Europe that had similar markings with the non-standard gold tube ink replete with misaligned letters. Heck, even one of the ‘date’ codes matched one of the tubes I bought. He had bought his tubes earlier than Kevin did, so I suspect the sellers found some used Telefunken tubes, put new markings on them as the original Telefunken ink was notorious for wearing off, put them in new boxes and sold them as NOS. That guy’s tubes tested out as very lousy. Word got out. I suspect what really happened is that in the first batch the sellers didn’t check the tubes for performance, and in Kevin’s batch they weeded out the duds.
Trouble is, they test well, according to Kevin. So are they fakes? Used? New/rebranded? (In the second link, above, it shows how the Telefunken symbol on the bottom of the tube can be faked with a laser)
I dunno. They are most likely fakes, but good enough to trick even Kevin. I’m waiting to get to 500 hours on the BHK before I do anything.
