Does any one use a universal remote, like Logitech Harmony to control the BHK Pre ? All my audio/video devices are controlled by a Logitech Harmony remote and would like to add the BHK pre to it as well but it doesn’t seem to find the Pre in its database. I know you can teach the remote to learn from the original remote but there are too many functions in the BHK remote since it can control the Transport/DAC as well. Wondering if there is any easy way ? maybe the model name registered in the database has a different name ?
I have a Harmony system remote as well. PS Audio DACs and Tranports codes are preloaded by Harmony. The BHK preamp not so much. I programmed it in learning mode 1 button at a time. I only use one source so it wasn’t as complicated for me. The good news is if you have a BHK power amp and use a trigger wire, you can put both the preamp, power amp (DAC & Trasport too) in standby at the touch of a button. The bad news is the Harmony volume control raises & lowers the pre-amp’s volume 3 numbers at a time.
Has any one found a selection on the Logitech Remote database that will work with the BHK Preamp? I am not looking forward to manually programing in the remote functions.
I used a Harmony Hub universal remote and I only had to program the volume function, which for some reason bumps volume up/down in steps of 3 at a time. Otherwise it’s fine.
–SSW
–SSW
I thought you could adjust the rate of volume change in the Harmony remote. I’m pretty sure I did this for my current Classe Sigma.
