BHK SIgnature Pre - display fail
Turned on my BHK pre today and the blue logo flashed as normal but with no display. The unit went through the warmup period and is playing music fine. The remote control is working and I can change input and volume. However there is no display on the unit and I have tried pressing the fascia button as well as the remote ‘On’ button.
Is there anything I should do before returning the unit?
try unplugging it for a few minutes. And if there’s an sd card in it, remove it.
Thanks RonP - thta worked!!! Not sure what happened but all is well now. Thanks again.
:grinning:
