Blinking Display On DirectStream II
Trying to turn on my Trigger I managed to disable the dac so I’ve got a slowly blinking display, can’t get out of it. Tried removing power. Any ideas ?
You don’t say how long you powered down, so I would suggest you turn off and unplug everything and let it sit for 24 hours. After that plug in without connecting anything and see if it boots up. If not call PS Audio.
Only 30 sec, yeah I’ll try 24 hrs, thks for suggestion
Well you nailed it, it’s back to normal today, thks again, never occurred to me to try a long power down. Btw I pulled the power cable, you think just using the rear power switch would have done the same ?
Got to pull my reply, I had repeated start up twice before declaring victory but now an hour later it’s blinking again :joy:. Time to call for help
Sounds like a component is changing after warming up.
Could be but since lock up occurred while I was adjusting the control ring I think that probably caused it. Wouldn’t think it should happen though.
