BRIDGE COMPATIBILITY
Hi,
is bridge 1 compatible with DSD Direct Stream?
thanks
F.
Yes. With the same issues and limitations.
Also the bridge needs to be running 0.2.15 or greater code.
Dennis
Good reminder Dennis. It’s best (by far) to update the Bridge firmware before moving it from a PWD to the DS.
But will i always benefit of the superior dsd sound quality right?
F.
Yes. The Bridge just give you another input to the DS. The DS does not care as much which input is used as the PWD (and Pike’s Peak supposedly narrows the differences some more) but I wouldn’t say they necessarily sound the same (it’s always going to depend on what the input is connected to and cables do matter somewhat too (some would say a lot)).
