It is so amazing, i like it very much! But i have kids at home, they are so interested to press the screen of p5, and they can change all setting or even turn off the whole system power. :p.
Thus, can I disable front panel logo button and touch screen? by website setting? Or some kind of children lock to p5?
Yes, you can disable the screen through the web interface. Make sure the unit is registered with us. Make sure you are registered with us.
Then,on the top right side of the website, where it says “Welcome KevinHo” hold your mouse over it. A list pops out and select “Control”. You should see the PowerPlant and go to it. The rest should be easy, most in the instruction manual.
Well, I was incorrect. Sorry. It was the PowerPlay products this worked on.
You can take the remote control and using the dim button, turn off the display. This does not disable it but it may make it less attractive to the little ones.
i figure it out how to disable the screen. First set all outlet to always on, then turn of the master power. The screeen will be off and no matter how kids touch it, make no difference.
