gazjam
1
Have both dac and pre,
I’m looking now at isolation products for them.
Checking weight the Tech Specs says they are both 31 lbs [14 kg]?
Is that right?
Websites and reviews dotted around show 22lbs?
Sure they felt different last time I was moving them on my shelf!
Thanks
Baldy
2
I have never weighed either one but they certainly could weigh the same amount as chassis and cabinetry are nearly the identical.
RonP
3
When you read their published specs, be sure you’re looking at “unit weight”, not “shipping weight”.
senna1a
4
My BHK pre weighs 21.8 lbs (I have the top metal screen removed).
Ron is correct. 31 lbs is the shipping weight.
gazjam
5
Thanks.
Looking at 4 x Isoacoustic Isopuck Minis, at 6lb capacity each,
So 4 under each unit ( at 24lbs) would hit the sweet spot.
senna1a
6
Yeah, I use (4) Bronze which have similar weight capacity- I think (4) Mini’s under each would work well.
