Connecting single sub to monoblocks
Hi,
I have the BHK pre and M1200s, also a single REL sub.
Can I use the high-level input to connect the REL given there’s no common ground? (REL I think advises against it).
I’ve looked but not found this answered anywhere else, apologies if I’ve missed it.
Very Best!
William.
I had this issue when I went from a stereo amp to pair of mono blocks.
Rel advised me quite clearly that you need two Rel subs for mono blocks, one for each amp.
So I had to purchase another Rel sub.
I initially got a S3 but have since upgraded to a S/812.
Thanks sherifd2… But actually, just come across this.
https://relsupport.zendesk.com/hc/en-us/articles/115004486607-Class-D-Amp-Connection-Methods
Suggesting earth lift on class D, i.e. don’t connector the ground, and let the rel use it’s own ground as the reference.
If that’s the case I have no issue right? And no danger of hum.
Am I reading this right? Sounds like the answer I need.
W.
Yes, you can hook it up like this with no problem. If you do get hum, you can either hook up a single ended cable like they recommend in that link, or you can connect the black to the M1200’s ground post.
:+1: all working nicely single ended.
Thanks James.
