I’m looking for a simple diagram on how to connect a single REL sub’s high level input to the monoblocks mentioned in the title with REL’s cable, as REL recommends using low level input for a single sub if using monoblocks.
Thanks.
Thanks.
REL has many nice diagrams and instructions on their website.
Or perhaps you wish a PS Audio person gives you instructions based on what they feel is best.
One subwoofer is a job half done though. Some people would say 1/6 done.
There is a reason REL says to use low level for that type of system as there is no “simple” way to connect one sub to two amps especially ones that don’t have a true ground.
