Great post and thanks for generously contributing.
+1
And welcome!
Welcome to the looney bin with the rest of us. Where els could you get a response from the Big Cheese, the designer and a well educated ruminant?
Nice post Mike
MikeK saidHey Mike, care to give a bit more detail in the comparison you've made between the PWD and the DS?Hi Folks,PPS Have to thank Paul and his recent post about community participation for prompting me to share my experience with you folks.
Sorry, been offline for a few days. Expand on the differences? Thought you’d never ask
I have to first take you back to early last year when I had a similar epiphany after acting on some room setup advice from one of Paul’s posts. For that change I moved the 800Ds well away from the walls and corners, more into the room (about 1/3 the room width funnily enough) positioned about 3m (10’) apart. I also moved the DB1s between the 800Ds, each of them about 300mm (1’) from each 800D and slightly behind the line between them. I then fitted the spiked feet to the speakers and subs which allowed me to slightly tilt forward the 800Ds at least. Lastly, after some experimentation, I set the speakers with a slight ‘toe-in’ such that they were still aimed away from the listening apex (about 3m from each speaker).
With this setup I heard a widening and deepening of the sound stage. Tilting the 800Ds forward also made it sound as though the instruments were playing at about ear level (from a seated position) rather than from above. When closing your eyes you could locate individual instruments in the sound space. So I guess you could say that the sound stage had become more ‘intimate’.
OK. Back to 2016 and the DirectStream/Bridge II (with Yale) upgrade. What was immediately apparent was a palpable sharpening of the focus on individual instruments. The effect was so startling I found myself being distracted by individual instruments - I’d focus on one and find I had to ‘force’ myself to listen to another.
The other distinctly noticeable improvement was what I’d call a persistence of notes in the bottom end. It wasn’t an increase as such but more a naturally sustained sound, attenuating over a longer time frame. Not sure if I described the image well enough but I hope you at least get the idea.
Very well described – sounds like a great improvement!
Thanks Mike
Hi everybody,
just upgraded from my pwd mkii Bridge i to DS bridge ii. What happens is simply incredible…all I can say is WOOOWWWWW. Before the upgade I wasnt sure, if it makes sense. Btw Bridge is my only source. Sound is so much more natural, precise, open, big, analog…you name it. Really, you should hear it. 10000% happy. Dont care about DS Junior, dont care about “after Yale”.
So damn happy…thanks Ted and Paul!
btw: installed a red fuse in the Ds as well.
Woot!!
