It may well be my imagination, but the DS appears to sound its best five to ten minutes after being turned on from cold.
The Power Plants produce a nice improvement. Remember, if you buy one you will be plugging the components of your system into the unit, not just the DS. The amount of improvement depends on both your components and the quality of your incoming power.
I leave mine on all,the time . I think at least thirty mins at a min. But some feel,itās much longer. I can add that with my krell amps and aragon,s itās 30 bare min and an hour is better. The same with my MSB and lampi . As I do try to convince myself how can it matter. It does to me. Even my tube amps 30 mins min .
al
gordon said Most of my gear has whiskers, I have had them for so long.I have the āmatchingā RCA MITs but , for now, I am running direct o my amp by Wireworld XLR. Iām not sure it is better SQ wise but it sure makes my rack less intimidating. [ pre has dual power supplies and adds 4 RCA more cables. 6moons audio reviews: FirstSound Presence Deluxe MkIII]
Trying out some different XLRs is on my short list but my short list is kinda long at the moment so will get to it when I can.
So you prefer your newer MIT speaker cables?
Last Aug I picked up a used pair of biwire MIT Magnum 1.3 - the cost (even used) was more than the value of my loudspeakers, but the improvement they brought to the system was amazing. They replaced an 8 year old set of Analysis Plus Oval 9 (top), and Oval 8 bi wire shotgun on the bottom. All interconnects are Grover Huffman ZX+ balanced. Iāve had no desire to change ICs.
louawalters saidLast Aug I picked up a used pair of biwire MIT Magnum 1.3 - the cost (even used) was more than the value of my loudspeakers,
Same here
louawalters saidAll interconnects are Grover Huffman ZX+ balanced. Iāve had no desire to change ICs.
Try MIT
LOL - well itās gonna have to wait, I just made a large purchase - new speakers - Von Schweikert VR5 Anniversary MK 2ās⦠Iām gonna be broke for a while
Grover Huffman cables are a low-cost option that do not come anywhere near high end options such as MIT, David Elrod, Shunyata, and others.
Elk said 1) It may well be my imagination, but the DS appears to sound its best five to ten minutes after being turned on from cold.
- The Power Plants produce a nice improvement. Remember, if you buy one you will be plugging the components of your system into the unit, not just the DS. The amount of improvement depends on both your components and the quality of your incoming power.
True on both accounts. I leave mine on always. So even when I travel with DS it still is ready go within only a few minutes.
I have been reading this for 70 pages and my DS is coming from dealer tonight. WOOHOO!
Welcome, Dave!
and mine is scheduled for FedEx delivery tomorrow!!
Thatās worth congratulations from a happy elk!
Ahhhhh, this is killinā me! Iām still slated for ālate Julyā, and Juneās not even over yet. The wait seems interminable.
Oh well⦠at least I have a PWD II to listen to in the meantime.
To stay on-topic: My initial impression is that the DS is really, really quiet.
The Direct Stream is always pictured with album art. Yet I have never seen any album art.
Should it?
I think you need the bridge to see art .
i think so anyway .
al
Yes Bridge is needed for art
Thanks ,I had a bridge once just once
I think artwork on the front panel is also software dependent. I donāt recall ever seeing it with anything other than eLyric.
stevem2 said I think artwork on the front panel is also software dependent. I don't recall ever seeing it with anything other than eLyric.No as I recall when my bridge was working it had art with JR, Pure Music, all my players.
Thanks for the comments.
Iām using a Bryston BDP2 player. The Album art show up on my Ipad but not on the Direct Stream.
