DirectStream DAC MK2 MountainTop - Mount Massive
Hey all!
here’s a direct link for download for the Mount Massive update for the DSD DAC MK2.
Thanks!
Sounds delicious
The “PerfectWave DSD MK2 Release Notes.pdf” file has zero bytes.
looking into it now
Think I will wait a day or so until a good version of this FPGA update is on the Downloads page.
I am still at 2.6.0. Should I update to the older 2.6.2 first and then to Massive or can I just use the latest 2.6.2 + Massive ?
I consistently get an error on unzipping the Massive file - have tried with Win 11 on 3 machines, same result. Can someone look at this and/or consider uploading an unzipped file?
just downloaded and installed 2.6.2 on third try…usually takes me longer
is there a burn in time ? I updated from 2.5.1
I just tried re-downloading and extracting with 7-Zip, which fails as does Win 11 - gives me headers error on massive.bin. if anyone has this file unzipped, please post or pm me. Thanks!
Sorry meant still at 2.5.1
I used the download at the top of this thread
Yup that one works, but the file in the main firmware page appears to be corrupt. Thanks!
The webteam is working on the replacement files on the site.
the link at top here seems to be gone
Should be fixed now
back up!
if my DS2 reads 2.6.2 does that mean i have the full download with Massive ? should it still read 208 Antero ? went into the menu on the DS2 and now it’s reading 228 Massive. … all is well
Massive is the FPGA load, the firmware version is still 2.6.2. Best course of action is follow the installation instructions in the file and load both.
thanks
