DirectStream DAC MKII Beta Tester Reviews
The green light was on when I first started using both I2S inputs.
The only green light I get is with optical! Football game sounds great!:joy:
I just gave my MK2 a name! Roxanne! You don’t have to put on the red light!
So far so interesting.
Streaming DSD64 streaming from Roon:
  1. i2S - With i2S 1 selected I have a red light and do not see the format playing. With the same paths as described below, I did see format on the MKI. Music plays without issue.
  2. USB - With USB selected I have a green light and do see the format. Music plays without issue.
My path for i2S: Roon Nucleus Plus → Ethernet → Ubiquity Unifi managed switch → Fiber → Ubiquity Unifi managed switch → Fiber → Sonore Signature Rendu SE → USB → Kitsune KTE SU-2 DDC → i2S → DS MKII i2S input 1.
My path for USB: Roon Nucleus Plus → Ethernet → Ubiquity Unifi managed switch → Fiber → Ubiquity Unifi managed switch → Fiber → Sonore Signature Rendu SE → USB → DS MKII USB input.
Also confirmed are the IR codes. Our Control 4 still controls the MKII in the same way it controlled the MKI.
Hmmmm. Admitting I may be missing something but after hooking all up, I get power on the transport, BHK pre, BHK amps, dac2.
Dac2 is input via wireworld I2S from transport. Connections seem correct 4x… ( I keep looking, expecting to find a doofus move. )
But there’s no audio at any volume setting on pre and dac2; mute is off on both. I2s1 shows on dac2.
Wild idea: could it be I have a dac2 w no software?
Help? I’ll call PS Monday if nobody knows.
Gee I hate to take everything apart again.
Have you tried moving to i2S input 2?
I assume the burn in is with disc playing, I.e.: not just power on. Post 189 explains my trouble. Thanks.
Yes, no luck.
Does the top right of the display track your inputs, e.g. I2S1, 44.1 24 ? If so you might have gotten bitten by the same bug as those whose units worked well for a while and then went mute. If the upper right doesn’t track your inputs then perhaps there is something wrong with the software load.
This seems wrong… might be the silence issue. Trying to play 16/44 cd.
44.1/32 on transport
44.1/24 on dac2
That is fixed in the new FPGA software (not yet released). I2S inputs are out of polarity so all zeros looks like all 1s in a sample. I thought that that bug was fixed in the last software I sent to PS Audio, but in any case, it’s fixed in the new code.
I just noticed that while playing DSD over USB, Roon isn’t passing on the DSD file, it is doing a DSD to PCM conversion to 352.8khz PCM. This happens when the Rendu is configured for “Native DSD”.
When I switch the Rendu to DoP, I hear burst of static, similar to the blat from a trumpet.
I have included diagnostic logs from the Rendu for both “Native DSD” and “DOP”.
This is the diagnostic log from the Rendu while the Rendu is set at “Native DSD” and streaming a DSD256 file over USB:
Roon Ready Diagnostic information BACK to Menu
DOWNLOAD
11/13/2022 17:22:21 - ------------------------------------------------------------
11/13/2022 17:22:21 - /opt/RoonReady/raatool logdump 518cad27-0646-4fd0-a010-402295cb2917
[0000000] 0.000 TRACE [info] initializing info dictionary
[0000001] 0.001 TRACE [info] inserting raat_version → 1.1.38
[0000002] 0.001 TRACE [info] inserting protocol_version → 3
[0000003] 0.006 TRACE [output/alsa] initializing output uniqueid=hw:0,0
[0000004] 0.006 TRACE [output/alsa] preferred buffer duration=0.050000s
[0000005] 0.006 TRACE [output/alsa] force_max_volume=0
[0000006] 0.006 TRACE [output/alsa] resync delay=0.100000s
[0000007] 0.006 TRACE [ALSA] max pcm rate=1411200
[0000008] 0.006 TRACE [output/alsa] max dsd rate=1024
[0000009] 0.006 TRACE [output/alsa] dsd_mode=native
[0000010] 0.006 TRACE [output/alsa] getting hardware info
[0000011] 0.007 TRACE pcm card id US
[0000012] 0.007 TRACE pcm card name PS Audio Extended Resolution US
[0000013] 0.008 TRACE pcm card longname PS Audio PS Audio Extended Resolution US at usb-ci_hdrc.1-1.1, high speed
[0000014] 0.008 TRACE pcm card mixername USB Mixer
[0000015] 0.008 TRACE pcm card components USB2616:0202
[0000016] 0.008 TRACE pcm card driver USB-Audio
[0000017] 0.008 TRACE pcm card usb id 2616:0202
[0000018] 0.008 TRACE [output/alsa] probing formats
[0000019] 0.009 TRACE [alsa] [hw:0,0] probing formats
[0000020] 0.010 TRACE [alsa] [hw:0,0] device supports channels range 2-2
[0000021] 0.010 TRACE [alsa] [hw:0,0] supports PCM format 44100/16/1
[0000022] 0.010 TRACE [alsa] [hw:0,0] supports PCM format 44100/24/1
[0000023] 0.010 TRACE [alsa] [hw:0,0] supports PCM format 44100/32/1
[0000024] 0.011 TRACE [alsa] [hw:0,0] supports PCM format 48000/16/1
[0000025] 0.011 TRACE [alsa] [hw:0,0] supports PCM format 48000/24/1
[0000026] 0.011 TRACE [alsa] [hw:0,0] supports PCM format 48000/32/1
[0000027] 0.011 TRACE [alsa] [hw:0,0] supports PCM format 88200/16/1
[0000028] 0.011 TRACE [alsa] [hw:0,0] supports PCM format 88200/24/1
[0000029] 0.011 TRACE [alsa] [hw:0,0] supports PCM format 88200/32/1
[0000030] 0.011 TRACE [alsa] [hw:0,0] supports PCM format 96000/16/1
[0000031] 0.011 TRACE [alsa] [hw:0,0] supports PCM format 96000/24/1
[0000032] 0.011 TRACE [alsa] [hw:0,0] supports PCM format 96000/32/1
[0000033] 0.011 TRACE [alsa] [hw:0,0] supports PCM format 176400/16/1
[0000034] 0.012 TRACE [alsa] [hw:0,0] supports PCM format 176400/24/1
[0000035] 0.012 TRACE [alsa] [hw:0,0] supports PCM format 176400/32/1
[0000036] 0.012 TRACE [alsa] [hw:0,0] supports PCM format 192000/16/1
[0000037] 0.012 TRACE [alsa] [hw:0,0] supports PCM format 192000/24/1
[0000038] 0.012 TRACE [alsa] [hw:0,0] supports PCM format 192000/32/1
[0000039] 0.012 TRACE [alsa] [hw:0,0] supports PCM format 352800/16/1
[0000040] 0.012 TRACE [alsa] [hw:0,0] supports PCM format 352800/24/1
[0000041] 0.012 TRACE [alsa] [hw:0,0] supports PCM format 352800/32/1
[0000042] 0.012 TRACE [alsa] [hw:0,0] supports PCM format 384000/16/1
[0000043] 0.012 TRACE [alsa] [hw:0,0] supports PCM format 384000/24/1
[0000044] 0.013 TRACE [alsa] [hw:0,0] supports PCM format 384000/32/1
[0000045] 0.013 TRACE [alsa] [hw:0,0] supports PCM format 705600/16/1
[0000046] 0.013 TRACE [alsa] [hw:0,0] supports PCM format 705600/24/1
[0000047] 0.013 TRACE [alsa] [hw:0,0] supports PCM format 705600/32/1
[0000048] 0.014 TRACE [alsa] [hw:0,0] supports PCM format 44100/16/2
[0000049] 0.014 TRACE [alsa] [hw:0,0] supports PCM format 44100/24/2
[0000050] 0.014 TRACE [alsa] [hw:0,0] supports PCM format 44100/32/2
[0000051] 0.014 TRACE [alsa] [hw:0,0] supports PCM format 48000/16/2
[0000052] 0.014 TRACE [alsa] [hw:0,0] supports PCM format 48000/24/2
[0000053] 0.014 TRACE [alsa] [hw:0,0] supports PCM format 48000/32/2
[0000054] 0.014 TRACE [alsa] [hw:0,0] supports PCM format 88200/16/2
[0000055] 0.014 TRACE [alsa] [hw:0,0] supports PCM format 88200/24/2
[0000056] 0.014 TRACE [alsa] [hw:0,0] supports PCM format 88200/32/2
[0000057] 0.014 TRACE [alsa] [hw:0,0] supports PCM format 96000/16/2
[0000058] 0.015 TRACE [alsa] [hw:0,0] supports PCM format 96000/24/2
[0000059] 0.015 TRACE [alsa] [hw:0,0] supports PCM format 96000/32/2
[0000060] 0.015 TRACE [alsa] [hw:0,0] supports PCM format 176400/16/2
[0000061] 0.015 TRACE [alsa] [hw:0,0] supports PCM format 176400/24/2
[0000062] 0.015 TRACE [alsa] [hw:0,0] supports PCM format 176400/32/2
[0000063] 0.015 TRACE [alsa] [hw:0,0] supports PCM format 192000/16/2
[0000064] 0.015 TRACE [alsa] [hw:0,0] supports PCM format 192000/24/2
[0000065] 0.015 TRACE [alsa] [hw:0,0] supports PCM format 192000/32/2
[0000066] 0.016 TRACE [alsa] [hw:0,0] supports PCM format 352800/16/2
[0000067] 0.016 TRACE [alsa] [hw:0,0] supports PCM format 352800/24/2
[0000068] 0.016 TRACE [alsa] [hw:0,0] supports PCM format 352800/32/2
[0000069] 0.016 TRACE [alsa] [hw:0,0] supports PCM format 384000/16/2
[0000070] 0.016 TRACE [alsa] [hw:0,0] supports PCM format 384000/24/2
[0000071] 0.016 TRACE [alsa] [hw:0,0] supports PCM format 384000/32/2
[0000072] 0.016 TRACE [alsa] [hw:0,0] supports PCM format 705600/16/2
[0000073] 0.016 TRACE [alsa] [hw:0,0] supports PCM format 705600/24/2
[0000074] 0.016 TRACE [alsa] [hw:0,0] supports PCM format 705600/32/2
[0000075] 0.030 TRACE [output/alsa] initialized
[0000076] 0.030 TRACE [volume/null] initialized
[0000077] 0.030 TRACE [watch/alsa] initializing watch device=hw:0 exit_on_lost=1
[0000078] 0.031 TRACE [watch/alsa] initialized
[0000079] 0.031 TRACE [info] inserting unique_id → 518cad27-0646-4fd0-a010-402295cb2917
[0000080] 0.031 TRACE [info] inserting vendor → Sonore
[0000081] 0.031 TRACE [info] inserting vendor_model → Sonore Signature Rendu SE
[0000082] 0.031 TRACE [info] inserting serial → 013B18
[0000083] 0.031 TRACE [info] inserting config_url → http://SELF/
[0000084] 0.031 TRACE [info] inserting model → Signature Rendu SE
[0000085] 0.031 TRACE [info] inserting version → 2.8
[0000086] 0.032 INFO [server] listening on port 33047
[0000087] 0.032 TRACE [discovery] starting
[0000088] 0.033 INFO [discovery] [iface:127.0.0.1] multicast recv socket is bound to 0.0.0.0:9003
[0000089] 0.033 INFO [discovery] [iface:127.0.0.1] multicast send socket is bound to 0.0.0.0:53354
[0000090] 0.033 INFO [discovery] [iface:192.168.86.147] multicast recv socket is bound to 0.0.0.0:9003
[0000091] 0.033 INFO [discovery] [iface:192.168.86.147] multicast send socket is bound to 0.0.0.0:57717
[0000092] 0.034 INFO [discovery] unicast socket is bound to 0.0.0.0:9003
[0000093] 0.034 TRACE [device] announcing DiscoveryMessage[type=QUERY, transactionid=10F30BF2-B5CF-BC0E-0545-C7B760CE8341, Data={ “unique_id”: “518cad27-0646-4fd0-a010-402295cb2917”, “raat_version”: “1.1.38”, “vendor”: “Sonore”, “protocol_version”: “3”, “config_url”: “http://SELF/”, “model”: “Signature Rendu SE”, “version”: “2.8”, “vendor_model”: “Sonore Signature Rendu SE”, “serial”: “013B18”, “service_id”: “5e2042ad-9bc5-4508-be92-ff68f19bdc93”, “tcp_port”: “33047”, } ]
[0000094] 0.076 DEBUG [discovery] broadcast op is complete
[0000095] 0.755 TRACE [server] [192.168.86.99:36340] accepted connection
[0000096] 0.766 TRACE [session] [192.168.86.99:36340] created: 0x1f29a40 (0x1f29fd8)
[0000097] 0.767 TRACE [server] new script with name=raat.dat:base.lua module=base
[0000098] 0.769 TRACE [session] [192.168.86.99:36340] pre-loading lua module base
[0000099] 0.779 TRACE [server] new script with name=raat.dat:dkjson.lua module=dkjson
[0000100] 0.780 TRACE [session] [192.168.86.99:36340] pre-loading lua module dkjson
[0000101] 0.780 TRACE [server] new script with name=raat.dat:protocol.lua module=protocol
[0000102] 0.792 TRACE [session] [192.168.86.99:36340] pre-loading lua module protocol
[0000103] 0.797 TRACE [server] new script with name=raat.dat:roon_tcp.lua module=(null)
[0000104] 0.797 TRACE [server] [192.168.86.99:36340] SENT[LL] [1] {“status”: “Success”}
[0000105] 0.797 TRACE [server] [192.168.86.99:36340] SENT[LL] [2] {“status”: “Success”}
[0000106] 0.798 TRACE [server] [192.168.86.99:36340] SENT[LL] [3] {“status”: “Success”}
[0000107] 0.798 TRACE [session] [192.168.86.99:36340] executing lua script
[0000108] 0.825 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] [roon] clock socket listening on udp 0.0.0.0:37442
[0000109] 0.825 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] [roon] audio socket listening on tcp 0.0.0.0:40863
[0000110] 0.825 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] [roon] output info {“alsa_device”: {“id”: “US”, “mixername”: “USB Mixer”, “name”: “PS Audio Extended Resolution US”, “driver”: “USB-Audio”, “longname”: “PS Audio PS Audio Extended Resolution US at usb-ci_hdrc.1-1.1, high speed”, “components”: “US”, “usbid”: “2616:0202”}, “config”: {“signal_path”: [{“type”: “output”, “quality”: “lossless”, “method”: “usb”}], “device”: “hw:0,0”, “type”: “alsa”, “dsd_mode”: “native”, “buffer_duration”: 0.050000000000000003}}
[0000111] 0.825 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] [roon] volume info {“config”: {“type”: “null”, “optional”: true}}
[0000112] 0.826 TRACE [server] [192.168.86.99:36340] SENT[LL] [4] {“status”: “Success”}
[0000113] 0.830 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] GOT [2] {“request”:“info”}
[0000114] 0.838 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] SENT [2] {“transport”:{“is_supported”:false,“info”:},“status”:“Success”,“info”:{“unique_id”:“518cad27-0646-4fd0-a010-402295cb2917”},“platform”:{“uname”:{“release”:“5.4.21-105.sgc.fc30.armv7hl”,“nodename”:“SignatureRendu”,“sysname”:“Linux”,“machine”:“armv7l”,“version”:“#1 SMP Sat Dec 4 11:05:08 EST 2021”},“os”:“linux”},“source_selection”:{“info”:,“is_supported”:false},“volume”:{“info”:{“config”:{“type”:“null”,“optional”:true}},“is_supported”:true},“flags”:{“has_write_chmap”:true},“output”:{“supported_formats”:“192000/32/1|2,96000/32/1|2,96000/24/1|2,48000/24/1|2,44100/32/1|2,705600/32/1|2,48000/32/1|2,88200/16/1|2,176400/32/1|2,352800/16/1|2,705600/16/1|2,705600/24/1|2,384000/32/1|2,48000/16/1|2,176400/16/1|2,384000/16/1|2,88200/32/1|2,176400/24/1|2,384000/24/1|2,88200/24/1|2,352800/32/1|2,352800/24/1|2,192000/24/1|2,192000/16/1|2,44100/16/1|2,44100/24/1|2,96000/16/1|2”,“info”:{“config”:{“dsd_mode”:“native”,“buffer_duration”:0.05,“type”:“alsa”,“device”:“hw:0,0”,"sign
[0000115] 0.839 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] GOT [3] {“request”:“set_client_type”,“client_type”:“Roon”}
[0000116] 0.840 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] SENT [3] {“status”:“Success”}
[0000117] 0.841 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] GOT [4] {“request”:“subscribe_transport”}
[0000118] 0.842 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] GOT [5] {“request”:“subscribe_controls”,“controller_id”:“5ee207d3-d39a-4d0b-9069-c086f0d0d653”}
[0000119] 0.844 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] SENT [5] {“status”:“Success”,“controls”:{“volume”:{“mute”:false,“type”:“none”,“min”:0.0,“step”:1.0,“value”:0,“info”:{“config”:{“type”:“null”,“optional”:true}},“max”:0.0}},“action”:“Changed”}
[0000120] 8.583 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] GOT [6] {“request”:“setup”,“format”:{“sample_type”:“pcm”,“sample_rate”:352800,“bits_per_sample”:32,“channels”:2,“sample_subtype”:“none”}}
[0000121] 8.583 TRACE alsa output setup: format is pcm 352800/32/2
[0000122] 8.583 TRACE opening [hw:0,0] 352800/32/2
[0000123] 8.585 TRACE prefer larger samples = 0
[0000124] 8.586 TRACE [ALSA] [hw:0,0] using hw pcmformat S32_LE bitspersample 32
[0000125] 8.586 TRACE [ALSA] [hw:0,0] Requesting 2 periods
[0000126] 8.586 TRACE [ALSA] [hw:0,0] Requesting 17640 frames/buffer (8820 frames/period)
[0000127] 8.587 TRACE [ALSA] [hw:0,0] Initialized with 2 periods with 8820 frames/period and 17640 frames/buffer
[0000128] 8.594 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] got output message {“signal_path”: [{“quality”: “lossless”, “type”: “output”, “method”: “usb”}]}
[0000129] 8.594 TRACE sched_setscheduler succeeded
[0000130] 8.594 TRACE samples per buf 8820 ns per buf 25000000 samplerate 352800
[0000131] 8.594 TRACE 8820 samples per buf, 70560 bytes per buf, 70560 bytes per hwbuf
[0000132] 8.594 TRACE [output/alsa] [hw:0,0] waiting for device to be ready
[0000133] 8.594 TRACE [output/alsa] [hw:0,0] device is ready
[0000134] 8.595 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] SENT [6] {“message”:{“signal_path”:[{“quality”:“lossless”,“type”:“output”,“method”:“usb”}]},“status”:“OutputMessage”}
[0000135] 8.627 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] SENT [6] {“audio_port_tcp”:40863,“status”:“Success”,“audio_port”:0,“clock_port”:37442}
[0000136] 8.642 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] GOT [7] {“request”:“stream”,“stream_id”:687075740,“first_seq”:-1,“nak_port”:-1,“buffer_size”:10,“ready_threshold”:0.2}
[0000137] 8.643 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] SENT [7] {“status”:“Buffering”}
[0000138] 9.203 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] SENT [7] {“status”:“Ready”}
[0000139] 10.031 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] GOT [8] {“request”:“start”,“min_offset”:70082199,“stream_sample”:0}
[0000140] 10.035 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] Doing ASAP start based on current device clock (min_offset=70082199)
[0000141] 10.036 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] SENT [7] {“status”:“Playing”}
[0000142] 10.038 TRACE [lua@0x1f29c2c] [192.168.86.99:36340] SENT [8] {“time”:1529199442,“status”:“Success”}
[0000143] 10.049 TRACE starting playback: now (1525000000ns) + ns_per_buf(25000000ns) = 1550000000ns > 1529199442ns streamsample=0
[0000144] 88.806 TRACE [server] [127.0.0.1:39624] accepted connection
[0000145] 88.812 TRACE [session] [127.0.0.1:39624] created: 0x1f3e0e8 (0x1f3e680)
11/13/2022 17:22:21 - aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: US [PS Audio Extended Resolution US], device 0: USB Audio [USB Audio]
Subdevices: 0/1
Subdevice #0: subdevice #0
This is the diagnostic log of the Rendu while set to “DoP” while streaming a DSD256 file over USB:
DOWNLOAD
11/13/2022 17:34:25 - ------------------------------------------------------------
11/13/2022 17:34:25 - /opt/RoonReady/raatool logdump 518cad27-0646-4fd0-a010-402295cb2917
[0000001] 0.002 TRACE [info] inserting raat_version → 1.1.38
[0000002] 0.002 TRACE [info] inserting protocol_version → 3
[0000003] 0.008 TRACE [output/alsa] initializing output uniqueid=hw:0,0
[0000004] 0.009 TRACE [output/alsa] preferred buffer duration=0.050000s
[0000005] 0.010 TRACE [output/alsa] force_max_volume=0
[0000006] 0.011 TRACE [output/alsa] resync delay=0.100000s
[0000007] 0.011 TRACE [ALSA] max pcm rate=1411200
[0000008] 0.012 TRACE [output/alsa] max dsd rate=1024
[0000009] 0.013 TRACE [output/alsa] dsd_mode=dop
[0000010] 0.014 TRACE [output/alsa] getting hardware info
[0000011] 0.016 TRACE pcm card id US
[0000012] 0.017 TRACE pcm card name PS Audio Extended Resolution US
[0000013] 0.018 TRACE pcm card longname PS Audio PS Audio Extended Resolution US at usb-ci_hdrc.1-1.1, high speed
[0000014] 0.018 TRACE pcm card mixername USB Mixer
[0000015] 0.018 TRACE pcm card components USB2616:0202
[0000016] 0.019 TRACE pcm card driver USB-Audio
[0000017] 0.019 TRACE pcm card usb id 2616:0202
[0000018] 0.019 TRACE [output/alsa] probing formats
[0000019] 0.020 TRACE [alsa] [hw:0,0] probing formats
[0000020] 0.020 TRACE [alsa] [hw:0,0] device supports channels range 2-2
[0000021] 0.020 TRACE [alsa] [hw:0,0] supports PCM format 44100/16/1
[0000022] 0.020 TRACE [alsa] [hw:0,0] supports PCM format 44100/24/1
[0000023] 0.020 TRACE [alsa] [hw:0,0] supports PCM format 44100/32/1
[0000024] 0.020 TRACE [alsa] [hw:0,0] supports PCM format 48000/16/1
[0000025] 0.021 TRACE [alsa] [hw:0,0] supports PCM format 48000/24/1
[0000026] 0.021 TRACE [alsa] [hw:0,0] supports PCM format 48000/32/1
[0000027] 0.021 TRACE [alsa] [hw:0,0] supports PCM format 88200/16/1
[0000028] 0.021 TRACE [alsa] [hw:0,0] supports PCM format 88200/24/1
[0000029] 0.021 TRACE [alsa] [hw:0,0] supports PCM format 88200/32/1
[0000030] 0.021 TRACE [alsa] [hw:0,0] supports PCM format 96000/16/1
[0000031] 0.021 TRACE [alsa] [hw:0,0] supports PCM format 96000/24/1
[0000032] 0.021 TRACE [alsa] [hw:0,0] supports PCM format 96000/32/1
[0000033] 0.021 TRACE [alsa] [hw:0,0] supports PCM format 176400/16/1
[0000034] 0.021 TRACE [alsa] [hw:0,0] supports PCM format 176400/24/1
[0000035] 0.022 TRACE [alsa] [hw:0,0] supports DSD format 2822400/1/1 (Encapsulated)
[0000036] 0.023 TRACE [alsa] [hw:0,0] supports PCM format 176400/32/1
[0000037] 0.024 TRACE [alsa] [hw:0,0] supports PCM format 192000/16/1
[0000038] 0.024 TRACE [alsa] [hw:0,0] supports PCM format 192000/24/1
[0000039] 0.024 TRACE [alsa] [hw:0,0] supports PCM format 192000/32/1
[0000040] 0.024 TRACE [alsa] [hw:0,0] supports PCM format 352800/16/1
[0000041] 0.024 TRACE [alsa] [hw:0,0] supports PCM format 352800/24/1
[0000042] 0.024 TRACE [alsa] [hw:0,0] supports DSD format 5644800/1/1 (Encapsulated)
[0000043] 0.024 TRACE [alsa] [hw:0,0] supports PCM format 352800/32/1
[0000044] 0.024 TRACE [alsa] [hw:0,0] supports PCM format 384000/16/1
[0000045] 0.024 TRACE [alsa] [hw:0,0] supports PCM format 384000/24/1
[0000046] 0.025 TRACE [alsa] [hw:0,0] supports PCM format 384000/32/1
[0000047] 0.025 TRACE [alsa] [hw:0,0] supports PCM format 705600/16/1
[0000048] 0.025 TRACE [alsa] [hw:0,0] supports PCM format 705600/24/1
[0000049] 0.025 TRACE [alsa] [hw:0,0] supports DSD format 11289600/1/1 (Encapsulated)
[0000050] 0.025 TRACE [alsa] [hw:0,0] supports PCM format 705600/32/1
[0000051] 0.025 TRACE [alsa] [hw:0,0] supports PCM format 44100/16/2
[0000052] 0.025 TRACE [alsa] [hw:0,0] supports PCM format 44100/24/2
[0000053] 0.025 TRACE [alsa] [hw:0,0] supports PCM format 44100/32/2
[0000054] 0.026 TRACE [alsa] [hw:0,0] supports PCM format 48000/16/2
[0000055] 0.026 TRACE [alsa] [hw:0,0] supports PCM format 48000/24/2
[0000056] 0.026 TRACE [alsa] [hw:0,0] supports PCM format 48000/32/2
[0000057] 0.026 TRACE [alsa] [hw:0,0] supports PCM format 88200/16/2
[0000058] 0.026 TRACE [alsa] [hw:0,0] supports PCM format 88200/24/2
[0000059] 0.026 TRACE [alsa] [hw:0,0] supports PCM format 88200/32/2
[0000060] 0.026 TRACE [alsa] [hw:0,0] supports PCM format 96000/16/2
[0000061] 0.027 TRACE [alsa] [hw:0,0] supports PCM format 96000/24/2
[0000062] 0.027 TRACE [alsa] [hw:0,0] supports PCM format 96000/32/2
[0000063] 0.027 TRACE [alsa] [hw:0,0] supports PCM format 176400/16/2
[0000064] 0.027 TRACE [alsa] [hw:0,0] supports PCM format 176400/24/2
[0000065] 0.027 TRACE [alsa] [hw:0,0] supports DSD format 2822400/1/2 (Encapsulated)
[0000066] 0.027 TRACE [alsa] [hw:0,0] supports PCM format 176400/32/2
[0000067] 0.027 TRACE [alsa] [hw:0,0] supports PCM format 192000/16/2
[0000068] 0.027 TRACE [alsa] [hw:0,0] supports PCM format 192000/24/2
[0000069] 0.027 TRACE [alsa] [hw:0,0] supports PCM format 192000/32/2
[0000070] 0.027 TRACE [alsa] [hw:0,0] supports PCM format 352800/16/2
[0000071] 0.028 TRACE [alsa] [hw:0,0] supports PCM format 352800/24/2
[0000072] 0.028 TRACE [alsa] [hw:0,0] supports DSD format 5644800/1/2 (Encapsulated)
[0000073] 0.028 TRACE [alsa] [hw:0,0] supports PCM format 352800/32/2
[0000074] 0.028 TRACE [alsa] [hw:0,0] supports PCM format 384000/16/2
[0000075] 0.028 TRACE [alsa] [hw:0,0] supports PCM format 384000/24/2
[0000076] 0.028 TRACE [alsa] [hw:0,0] supports PCM format 384000/32/2
[0000077] 0.028 TRACE [alsa] [hw:0,0] supports PCM format 705600/16/2
[0000078] 0.028 TRACE [alsa] [hw:0,0] supports PCM format 705600/24/2
[0000079] 0.028 TRACE [alsa] [hw:0,0] supports DSD format 11289600/1/2 (Encapsulated)
[0000080] 0.028 TRACE [alsa] [hw:0,0] supports PCM format 705600/32/2
[0000081] 0.048 TRACE [output/alsa] initialized
[0000082] 0.048 TRACE [volume/null] initialized
[0000083] 0.048 TRACE [watch/alsa] initializing watch device=hw:0 exit_on_lost=1
[0000084] 0.048 TRACE [watch/alsa] initialized
[0000085] 0.048 TRACE [info] inserting unique_id → 518cad27-0646-4fd0-a010-402295cb2917
[0000086] 0.048 TRACE [info] inserting vendor → Sonore
[0000087] 0.048 TRACE [info] inserting vendor_model → Sonore Signature Rendu SE
[0000088] 0.049 TRACE [info] inserting serial → 013B18
[0000089] 0.049 TRACE [info] inserting config_url → http://SELF/
[0000090] 0.049 TRACE [info] inserting model → Signature Rendu SE
[0000091] 0.049 TRACE [info] inserting version → 2.8
[0000092] 0.049 INFO [server] listening on port 32803
[0000093] 0.049 TRACE [discovery] starting
[0000094] 0.055 INFO [discovery] [iface:127.0.0.1] multicast recv socket is bound to 0.0.0.0:9003
[0000095] 0.055 INFO [discovery] [iface:127.0.0.1] multicast send socket is bound to 0.0.0.0:47132
[0000096] 0.056 INFO [discovery] [iface:192.168.86.147] multicast recv socket is bound to 0.0.0.0:9003
[0000097] 0.056 INFO [discovery] [iface:192.168.86.147] multicast send socket is bound to 0.0.0.0:55959
[0000098] 0.056 INFO [discovery] unicast socket is bound to 0.0.0.0:9003
[0000099] 0.056 TRACE [device] announcing DiscoveryMessage[type=QUERY, transactionid=80B43640-FDF3-9C00-4B90-D46733C1158F, Data={ “unique_id”: “518cad27-0646-4fd0-a010-402295cb2917”, “raat_version”: “1.1.38”, “vendor”: “Sonore”, “protocol_version”: “3”, “config_url”: “http://SELF/”, “model”: “Signature Rendu SE”, “version”: “2.8”, “vendor_model”: “Sonore Signature Rendu SE”, “serial”: “013B18”, “service_id”: “5e2042ad-9bc5-4508-be92-ff68f19bdc93”, “tcp_port”: “32803”, } ]
[0000100] 0.101 DEBUG [discovery] broadcast op is complete
[0000101] 0.785 TRACE [server] [192.168.86.99:51498] accepted connection
[0000102] 0.795 TRACE [session] [192.168.86.99:51498] created: 0x1ebe240 (0x1ebe7d8)
[0000103] 0.797 TRACE [server] new script with name=raat.dat:base.lua module=base
[0000104] 0.798 TRACE [session] [192.168.86.99:51498] pre-loading lua module base
[0000105] 0.807 TRACE [server] new script with name=raat.dat:dkjson.lua module=dkjson
[0000106] 0.808 TRACE [session] [192.168.86.99:51498] pre-loading lua module dkjson
[0000107] 0.809 TRACE [server] new script with name=raat.dat:protocol.lua module=protocol
[0000108] 0.822 TRACE [session] [192.168.86.99:51498] pre-loading lua module protocol
[0000109] 0.826 TRACE [server] new script with name=raat.dat:roon_tcp.lua module=(null)
[0000110] 0.826 TRACE [server] [192.168.86.99:51498] SENT[LL] [1] {“status”: “Success”}
[0000111] 0.826 TRACE [server] [192.168.86.99:51498] SENT[LL] [2] {“status”: “Success”}
[0000112] 0.827 TRACE [server] [192.168.86.99:51498] SENT[LL] [3] {“status”: “Success”}
[0000113] 0.827 TRACE [session] [192.168.86.99:51498] executing lua script
[0000114] 0.850 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] [roon] clock socket listening on udp 0.0.0.0:57488
[0000115] 0.850 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] [roon] audio socket listening on tcp 0.0.0.0:43307
[0000116] 0.850 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] [roon] output info {“config”: {“type”: “alsa”, “device”: “hw:0,0”, “signal_path”: [{“quality”: “lossless”, “type”: “output”, “method”: “usb”}], “buffer_duration”: 0.050000000000000003, “dsd_mode”: “dop”}, “alsa_device”: {“longname”: “PS Audio PS Audio Extended Resolution US at usb-ci_hdrc.1-1.1, high speed”, “id”: “US”, “name”: “PS Audio Extended Resolution US”, “driver”: “USB-Audio”, “mixername”: “USB Mixer”, “usbid”: “2616:0202”, “components”: “US”}}
[0000117] 0.851 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] [roon] volume info {“config”: {“type”: “null”, “optional”: true}}
[0000118] 0.851 TRACE [server] [192.168.86.99:51498] SENT[LL] [4] {“status”: “Success”}
[0000119] 0.852 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] GOT [2] {“request”:“info”}
[0000120] 0.859 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] SENT [2] {“source_selection”:{“is_supported”:false,“info”:},“platform”:{“uname”:{“nodename”:“SignatureRendu”,“release”:“5.4.21-105.sgc.fc30.armv7hl”,“sysname”:“Linux”,“machine”:“armv7l”,“version”:“#1 SMP Sat Dec 4 11:05:08 EST 2021”},“os”:“linux”},“volume”:{“is_supported”:true,“info”:{“config”:{“type”:“null”,“optional”:true}}},“flags”:{“has_write_chmap”:true},“transport”:{“is_supported”:false,“info”:},“status”:“Success”,“output”:{“supported_formats”:“88200/24/1|2,44100/24/1|2,384000/16/1|2,352800/24/1|2,96000/32/1|2,2822400/1/1|2,705600/24/1|2,705600/16/1|2,5644800/1/1|2,96000/16/1|2,176400/16/1|2,44100/16/1|2,384000/24/1|2,192000/24/1|2,96000/24/1|2,48000/16/1|2,192000/16/1|2,88200/32/1|2,705600/32/1|2,48000/32/1|2,384000/32/1|2,352800/32/1|2,192000/32/1|2,352800/16/1|2,176400/32/1|2,44100/32/1|2,11289600/1/1|2,88200/16/1|2,176400/24/1|2,48000/24/1|2”,“info”:{“config”:{“signal_path”:[{“type”:“output”,“quality”:“lossless”,“method”:“usb”}],“dsd_mode”:“dop”,“device”:"
[0000121] 0.860 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] GOT [3] {“request”:“set_client_type”,“client_type”:“Roon”}
[0000122] 0.861 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] SENT [3] {“status”:“Success”}
[0000123] 0.862 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] GOT [4] {“request”:“subscribe_transport”}
[0000124] 0.862 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] GOT [5] {“request”:“subscribe_controls”,“controller_id”:“5ee207d3-d39a-4d0b-9069-c086f0d0d653”}
[0000125] 0.864 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] SENT [5] {“status”:“Success”,“action”:“Changed”,“controls”:{“volume”:{“min”:0.0,“max”:0.0,“mute”:false,“type”:“none”,“step”:1.0,“value”:0,“info”:{“config”:{“type”:“null”,“optional”:true}}}}}
[0000126] 23.988 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] GOT [6] {“request”:“setup”,“format”:{“sample_type”:“dsd”,“sample_rate”:11289600,“bits_per_sample”:1,“channels”:2,“sample_subtype”:“none”}}
[0000127] 23.988 TRACE alsa output setup: format is dsd 11289600/1/2
[0000128] 23.989 TRACE opening [hw:0,0] 11289600/1/2
[0000129] 23.991 TRACE prefer larger samples = 0
[0000130] 23.991 TRACE [ALSA] [hw:0,0] using hw pcmformat S32_LE bitspersample 24
[0000131] 23.992 TRACE [ALSA] [hw:0,0] Requesting 2 periods
[0000132] 23.992 TRACE [ALSA] [hw:0,0] Requesting 35280 frames/buffer (17640 frames/period)
[0000133] 23.992 TRACE [ALSA] [hw:0,0] Initialized with 2 periods with 17640 frames/period and 35280 frames/buffer
[0000134] 24.000 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] got output message {“signal_path”: [{“quality”: “lossless”, “type”: “output”, “method”: “usb”}]}
[0000135] 24.000 TRACE sched_setscheduler succeeded
[0000136] 24.000 TRACE samples per buf 17640 ns per buf 25000000 samplerate 705600
[0000137] 24.001 TRACE 17640 samples per buf, 70560 bytes per buf, 141120 bytes per hwbuf
[0000138] 24.001 TRACE [output/alsa] [hw:0,0] waiting for device to be ready
[0000139] 24.001 TRACE [output/alsa] [hw:0,0] device is ready
[0000140] 24.001 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] SENT [6] {“message”:{“signal_path”:[{“type”:“output”,“quality”:“lossless”,“method”:“usb”}]},“status”:“OutputMessage”}
[0000141] 24.054 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] SENT [6] {“clock_port”:57488,“status”:“Success”,“audio_port_tcp”:43307,“audio_port”:0}
[0000142] 24.070 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] GOT [7] {“request”:“stream”,“stream_id”:502459488,“first_seq”:-1,“nak_port”:-1,“buffer_size”:10,“ready_threshold”:0.2}
[0000143] 24.071 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] SENT [7] {“status”:“Buffering”}
[0000144] 24.220 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] SENT [7] {“status”:“Ready”}
[0000145] 24.228 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] GOT [8] {“request”:“start”,“min_offset”:70555555,“stream_sample”:0}
[0000146] 24.229 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] Doing ASAP start based on current device clock (min_offset=70555555)
[0000147] 24.229 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] SENT [7] {“status”:“Playing”}
[0000148] 24.230 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] SENT [8] {“time”:235039555,“status”:“Success”}
[0000149] 24.233 TRACE waiting for start time…
[0000150] 24.279 TRACE starting playback: now (225000000ns) + ns_per_buf(25000000ns) = 250000000ns > 235039555ns streamsample=0
[0000151] 31.213 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] GOT [9] {“request”:“stop”}
[0000152] 31.221 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] SENT [7] {“status”:“Stopped”}
[0000153] 31.223 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] SENT [9] {“status”:“Success”}
[0000154] 36.214 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] GOT [10] {“request”:“end_stream”}
[0000155] 36.221 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] SENT [7] {“status”:“Ended”}
[0000156] 36.231 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] SENT [10] {“status”:“Success”}
[0000157] 36.232 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] GOT [11] {“request”:“teardown”}
[0000158] 36.232 TRACE [alsa] teardown
[0000159] 36.347 TRACE [lua@0x1ebe42c] [192.168.86.99:51498] SENT [6] {“status”:“Teardown”}
[0000160] 440.408 TRACE [server] [127.0.0.1:47554] accepted connection
[0000161] 440.415 TRACE [session] [127.0.0.1:47554] created: 0x1ec9f28 (0x1eca4c0)
11/13/2022 17:34:26 - ------------------------------------------------------------
11/13/2022 17:34:26 - aplay -l
Subdevices: 1/1
That’s suggestive of something up the chain from the DS is doing math on the samples. Everything needs to be verified that they are passing the bits thru unscathed. I believe that the bit perfect test will be in the next software release from PS Audio.
Agreed. I am wondering if there’s an issue with the PS Audio Extended Resolution driver. I think up above in the topic it was mentioned prior by someone streaming from a PC.
I am going to go back to i2S and let it burn in.
Tried to reboot dac2; get ps audio screen then no delay as was case while dac1 would initialize.
The DS Mk II boots almost instantly. Since you were getting an output on the screen which was consistent with your source (modulo the bit inversion bug in I2S) your software is very probably working fine. You can read the list of known issues by clicking the link in the first post on this thread.
I have good and bad news. First the good.
My brother is over and we came to the same conclusions, This MKII walked all over my modified MKI. Voices sounded more real and more present, better tone and air to high frequencies, much clearer and present soundstage…, not close at all!
Next I took out my Esoteric C-02 preamp and the sound got leaner and a bit sharp. Definitely much better with the preamp in the mix. The preamp gives a even better and complete picture of the music. The preamp stays.
Next we tried the USB input. This is the bad news. It cannot play DSD256. Although I believe the sound could be quite close to the Matrix and I2S. I’ll have to wait and see if Ted can fix this issue before I go on.
Later maybe another day, my brother will bring over his Esoteric N-01XD and we’ll do another shootout.
This is within the first hour of turning the unit on, so things can still get much better as times goes.
Since you are running different FPGA software than I thought was released, perhaps only having one input connected to the DAC will work, or perhaps using TOSLink or AES3 will work. Bugs that at times had those symptoms were fixed earlier.
Get green light on I2S 1 w nothing plugged into it.
Screen says input 1 is grounded (as is 2) with no I2S plug in 1.
Firmware 2.3.0
I am also on 2.3.0
