Elk saidMeaning I find many recordings of the music I listen to, on a neutral system in my room, to sound analytical and not musical. Sure if you pick them apart, they will have their redeeming features like detail, treble extension, clarity, propulsive rhythm section, etc. but musical involvement and flow will be absent. Again, my analogy to reproduction on a Krell system I used to own.Meaning you think the vast majority of recordings are awful to listen to?
Are you stating you find that most (all?) recordings need the midrange emphasized? That they are all flawed with a recessed midrange? Do you find the flaw to be the same with all recordings, or does it vary from recording to recording?
The best to address this would be to use a player which accepts VST plug-ins and add EQ as desired. I suspect that what you find to be necessary midrange sweetening might not be what others want.
I am saying that these recordings I listen to, on a neutral system, in my room, benefit from midrange richness. From what Jazznut is saying, I believe he shares this view
“But if a certain harmonic richness in mids is missing somewhere or from a main component, this not only influences nearly all kinds of recordings at the same time, but also is nearly impossible to influence/improve to the point afterwards.”
“Back to where we came from: IMO near “uncolored, extremely neutral” gear (as acoustics) tends to encourage analytic, comparable listening of good and similar recorded music while little richer sounding gear or acoustics or neutral gear with tonal tweaking options encourages to explore a wider musical spectrum and more focus on the music.”
I find even in some already decent recordings that a slight added midrange emphasis causes no harm - it’s just a different presentation that doesn’t detract from the musical message but brings it out in another way. In my system, it came out as the vocalist being a solid presence in the room, as opposed to the voice with more “mouth” effect filling the room. Who is to say which is more correct? Neither are exactly live. Both are pleasant to listen to.
I was disagreeing with your contention that the problem lies in the system and not the recording. Ultimately, both should work together to provide the listener with a pleasurable musical experience.
My system already veers towards some midrange richness but adding the DS into the chain took that away to the extent that it affected the musicality for me. It is a small amount but in these matters, small amounts have a large effect.
To this end, I agree with your views on personalised EQ. Perhaps a selectable filter or firmware can be made available for the DS in future. This is why I asked if there is an older firmware which retains most of the attributes of Torreys but with midrange richness.
Do you listen to any of the music we discussed above? Do you find blaring brass like in a Pharoah Sanders blowfest played on a neutral system not hard and grating on the ear so as to make you want to turn the volume down but doing so will obscure the detail when the piano and rhythm section come on? I guess it all comes down to taste.
I recently read a review in a popular online version of a magazine that describes Trane’s “A Love Supreme” as sounding warm. I don’t think that would be a descriptor I would have applied to it ever but listening to it on a Harbeth or Rogers fronted system with a full on midrange bump, it was darn pleasant.
From what I have heard so far, the DS, in my system, needs some midrange richness and ultimately may not be right for me. I do like and appreciate what it does and would like to keep it. At least enough to try a few cable tweaks. What is the received wisdom on power cables with the DS? If the DS does go, it will be the shortest lived component in my setup.
