Elk said
jazznut said
You can only hear the real intention of the engineer on his mastering monitors.
There is some truth to this on a theoretical level, but a good recording will sound good on any competent system. It will not sound bass shy, hot, dynamically compressed, etc. - unless this is what the engineer intended, or the playback system is deficient. One reason this is true is there is a good amount of standardization/commonality in how recordings are created. You may find Bob Katz's book, Mastering Audio interesting in this regard.
One of the primary concerns of the mixing and mastering engineers is that the recording translates well; that is, it sounds good on systems other than on which it is mastered. If this were not true, we would not enjoy the vast majority of recordings. Only the occasional random recording would sound decent.
Instead we have tens of thousands of very good to excellent sounding recordings, many of which nearly everyone agrees possess wonderful sound. A great example is the wonderful orchestral recordings of the 1950’s and early 1960’s. The recording and monitoring chain was vastly different than what is available today, especially highly colored and limited range speakers, but the recordings are magnificent on even the best, most revealing modern system.
I submit that if the majority of recordings do not sound good on a system, the problem lies with the system - not the recordings.
Of course, there is dreck out there. There are also old recordings were the technology did not yet exist to capture decent sound. These can be helped by judicious, thoughtful EQ.
And it is a hobby; if one enjoys fiddling with the sound of even the best recordings, fiddle away.
Many points to agree here, especially that most recordings can and should sound good on a certain setup as well as the better a system gets, the more fun there is aside of tonality discussions. Just some points I see differently.
Although I sometimes hear quite unbelievable tonal differences to any “standard” even in exceptionally good recordings/masterings, I agree that nearly all good ones can be played without any tweaking. These were not the ones I spoke of for a fiddling need.
More general examples of exceptions could be:
take some exceptionally rich recorded albums like Holly Cole/Temptation or most Donald Fagen recordings and play them after some like Dave Brubeck/Time out or most Blue Note or some other golden era Jazz. All that stuff was mastered/remastered by best engineers in a great way. But I say it’s definitely not possible to play both on one system without tonal tweaking so that both sound “right” in terms of “commonly agreed” tonal balance how you would want to hear it live.
The recording analyst and purist says: nice I can exactly hear that the one sounds great but on the edge of “too fat” while the other sounds great but van Gelder seemed to intend some brighter sound with close to no richness and bass in comparison to the first. Both very well done and mastered to the intent of the producer (as far as this can be said about RVG or others and how theywould have wanted their recordings to sound on today’s equipment)
But the, lets call him “pure music lover” wants to hear both in a tonally fully satisfying way and therefore, if he had a +/- few dB bass button on his remote, he would quickly press it the one or other time. Even with some of the “best recordings”.
You’re defending the engineering/mastering business, which is fine and correct with me, they all usually do a great job and most of their work does need no fiddling with tonality. But many listeners don’t want to hear (exaggerated) just 2L, Reference Recordings, Patricia Barber or Ms. Barlow, Cole or Krall in realistic tonality, but also their 60s Jazz or 80s Rock CD’s and don’t not want to give up on 50% of their favorite music just because they bought a high end stereo. And I’m not talking about the dreck out there, this needs no notice.
50s/60s Classical recordings indeed are a good example to still sound fantastic. Big exception to me is most (not all) of the Living Stereo stuff, not only because I dislike most Reiner interpretations, but mainly because in comparison to modern classical recordings I think especially the tonality is far from the real thing if not played with a very special person n this case really colored vinyl rig, while dynamics is great.
Back to where we came from: IMO near “uncolored, extremely neutral” gear (as acoustics) tends to encourage analytic, comparable listening of good and similar recorded music while little richer sounding gear or acoustics or neutral gear with tonal tweaking options encourages to explore a wider musical spectrum and more focus on the music.
You can easily check this by playing music on a high end system to non high end oriented but music loving friends or women. They will be just partly overwhelmed (for the part that also tonally sounds quite perfect). What they (not I) really need to have fun is a slighty bass heavy sound of any kind of music, just as most everyone prefers in a live concert. No need of a high end system. Another easy way to find out this is to try to convince them (not me) of the value of being able to analyze differences in the presumed intention of recording engineers instead of listening to all the music in an equally good tonality
Just to add this: all the recording differences are just one reason why some optional tonal adjustments in one part of a system can make sense. The other is, that all good recording/mastering is tuned to perfect room acoustics which just a minority even of high end system owners has. The major part of them listens to recordings mastered to not their acoustic environment on components not voiced to their acoustic environment (exaggerated) with no option to compensate except finding the exact mix of components with best match, with hopefully no reason to change too soon in one part that could change it all (like it happened to yacheah)
