Do P5 and P10 use the same fuse?
i just purchased a P10 as an upgrade to my P5. I’d like to know if I can use the Synergistic Red fuse I purchased for my P5 in the P10. I won’t have the P10 for a couple weeks and if I need a different fuse type/size I’d like to order it now so I can put it in before I install the P10.
Thanks!
According to what I found on the Internet, they both use a small (20mm) slow blow T5A fuse.
Joe Appierto said According to what I found on the Internet, they both use a small (20mm) slow blow T5A fuse.
My web research was inconclusive, so thanks!!
