In the documentation it is written that the fuse within P10 is slow-blow 3A/250V (for European version). However when I removed the one put from the factory (I guess as I bought it brand new) it was a 3A/250V Fast.
So which type are we actually supposed to put in it, fast blow or slow blow ?
Hi
I’m new to forum.
Wouldnt be better if the fuse was at least 1500watt/230V+ losses = at least 8-10 amps?
“Wouldnt be better if the fuse was at least 1500watt/230V+ losses = at least 8-10 amps?”
That is an interesting question.
The fuse is obviously under rated to handle all the current that a P10 would
draw at full capacity.
There is a high current (10 amp or 15 amp depending on input voltage) breaker on the back panel.
So, what is the fuse actually protecting?
