I’m considering a used DS Memory Player.
Will SACD playback work on DSJR, or will I need a DSDAC to be able to do SACD through I2S?
Is it a recommended combination?
Yes,the jr will play sacd discs via i2s.
Yes, it should work on the DSJ as long as it has there correct firmware version installed, which is not hard to do if it doesn’t.
Got the Jr + DMP combo. Sounds great with SACDs.
