Hello,
I have a direct stream DAC and use the bridge II to play music from my computer. I can no longer play SACD ISOs. This used to work, but I am not sure what broke it. I have posted to JRiver forum here: SACD playback no longer works?
Hello, I recently upgraded to MC 26. When I select an SACD track to play on my external DAC (PS Audio DS, via bridge II), it “looks” like it is playing - the progress bar is moving through the song, but I don’t hear it. In JRemote it shows it is starting to play and then restarts after a few seconds and this repeats over and over. This used to work… File Type is ‘sacd’ ; media type is ‘Audio’; sample rate is DSD64 (1x).
Tools; Options; Media and Network; Client Options; Audio Conversion is set to ‘Convert Audio if necessary’ and Encoder: PCM 24-bit.
The file does play through my computer. Any help is appreciated.
I also saw this: https://forum.psaudio.com/t/bridge-2-update-suddenly-no-iso-sacd-playback-jriver/13557
Bridge firmware shows “up to date” (on 4/12/2020).
Could someone point me to a solution?
