DS links with Mac via Bridge 1 card
I just installed Bridge 1 card into my DS and links it with an Ethernet cable to a Mac, no router used.
I found JRiver on mac could not found DS via Ethernet, presumed I need to setup IP address and subnet on DS, where can I find detailed steps to set it up properly?
Appreciated your help.
Johnney
Are you using a standard ethernet cable or a crossover cable? The latter is required when connecting the Bridge directly to a computer without going through a router or network switch.
just installed a crossover cable to link Mac with Bridge 1 of DSD.
On Mac and DSD side, if I select DHCP, no sound output via JRiver, then I select manual as below, still no sound output. Anywhere I should modify?
Mac:
IP: 192.168.0.1
Subnet: 255.255.255.0
Bridge:
IP: 192.168.0.2
Subnet: 255.255.0.0
Gateway: 192.168.249.1
Primary DNS: 192.168.249.204
Secondary DNS: 192.168.249.206
Please double-check your subnet. They must both be the same: 255.255.255.0 is most common. The rest looks okay.
J.P.
Thanks a lot! Magister & JP
Finally, after one year, I can play music via bridge instead of USB port. I currently using Jriver MC 22 for Mac, any tips for best setting to get sound quality and album art from MC 22?
I reviewed “How To xxx” and noticed some setting are different than in MC 22.
Well done, Magister and Wingsounds 13!
