Ok, I have try to understand how to? but I don’t get it? sorry
So Help?
What do i use to listen music from my computer to be in I2s?
Also, If i want to play in DSD, what do I do, with my computer to make it work?
thanks for any help, you could provide? I have check sonore, but there is so many device!
Just want a simple solution, without multiplying device, is it possible?
the rest is finally all set up and work great.
thanks
ps, just a verification, on my gain cell dac, it always show 48khz sampling, even if i change all in the computer, the only thing it saw is 48?
Also for updating driver does Stellar DAC does it equal Stellar DAC gain cell?
or the Stellar Gain cell, is not supported anymore?
