Dsd nuwave i2s pinout
Hello,
I recently bought a eversolo t8 to use the i2s connection and see how that sounds. But i cant seem to find the correct pin out for this dac, can someone help?
There’s a chart linked in the second post in this thread. Assuming all Eversolo are created equal you should find what you’re looking for.
I have a T8 as well. For use with the Direct Stream MK 1’s IIS I use mode 4 with channels reversed for PCM (DSD is correct). You must have firmware 1.5.30 for the reverse channels feature.
I have a nuwave dsd dac. I love it. I got sound but pcm is flipped
