Eversolo T8
The Eversolo T8 has eight I2S modes. Does anybody know which mode is best for the PSAudio MKII DAC?
Mode 5
Thank you!
Same for T8 to Mk1 ?
Thank you
As far as I know
Thank you. 5 and 1 work well. That narrows it down. Working with this. Not sure if it’s accurate but probably won’t start any fires experimenting….
Thank you. It seems to be 1 or 5. They are identical (in the manner the configurator mentions on pin 15 and 16) however data + - on DATA and LRCK are reversed. I was using 1 as the imaging seemed to center when switching from 5.
But easy to experiment with. And down to two options is a good thing.
