Looking for HDMI-I2S pin-out diagram
Looking to fabricate a HDMI cable to carry audio I2S signals from a PS Audio transport to a Holo May DAC. What is the correct 19 pin HDMI pinout diagram? Is this one correct?
|1| GND — Ground (Common ground for signal integrity)|
|2| LRCK (Word Clock) — Left/Right Clock (Word Clock, syncs audio)|
|3| GND — Ground (Common ground)|
|4| SCL — I2C Clock (optional for device control)|
|5| SDA — I2C Data (optional for device control)|
|6| GND — Ground (Common ground)|
|7| SD (Serial Data) — I2S Audio Data (main audio data stream)|
|8| GND — Ground (Common ground)|
|9| MCLK — Master Clock (DAC clock synchronization)|
|10| GND — Ground (Common ground)|
|11|+5V — 5V Power (used for signal integrity, optional)|
|12| NC - Not Connected (Unused)|
|13| NC - Not Connected (Unused)|
|14| NC - Not Connected (Unused)|
|15| NC - Not Connected (Unused)|
|16| NC - Not Connected (Unused)|
|17| NC - Not Connected (Unused)|
|18| NC - Not Connected (Unused)|
|19| GND — Ground (Common ground)|
Thanking you in advance — Pete
Pete
Here is a link to a chart that Jesus from Sonore compiled a while back. Not sure how “current” it is but it has the usual suspects in it including PS Audio.
Thank you!
For Triode Pete. I posted a similar question a few days ago and this thread was cited. I wonder if you had any luck in fabricating a correct HDMI cable.
Thanks
Yes he did, he posted about it in his section on Audio Circle.
Yes, it worked out very well sonically!
Cheers - Pete
Pete and Dawkins, thanks for the replies.
I studied Pete’s original post #1 and the Sonore spread sheets referenced in Dawkins’ post #2.
Just to be sure I understand, I’m assuming that the pin-out in Pete’s Post #1 is the plan endorsed by both of you.
Many thanks,
Warren
Hello Warren - Please use Dawkin’s attachment. That’s what I used and it worked brilliantly.
Sorry to be dense; there is a lot of data in the attachment. I see two identical PSA pin-outs. This one for the Power Wave DAC an seems the most likely.
||PS Audio PWD
MKI/MKII, PWT|
|1|SD (-)|
|2|GND|
|3|SD|
|4|BCK|
|5|GND|
|6|BCK (-)|
|7|L/RCLK (-)|
|8|GND|
|9|L/RCLK|
|10|MCLK|
|11|GND|
|12|MCLK (-)|
|13|NOT USED|
|14|NOT USED|
|15|SCL - i2c|
|16|SDA - i2c|
|17|GND|
|18|NOT USED|
|19|GND|
Yes, the pinouts were the same for all of the DACs from the Perfectwave forward as well as the disc transports.
thx
