I can’t get DSD256 to play via the Airlens > DirectStream (Sr). Using JRiver MC34. Does the Airlens need to be set a certain way or is it in the JRiver settings? I have JRiver set to “DSD.” Can someone point me in the right direction please.
HI @Timequest,
Perhaps this will help you.
Thanks, ‘mycrowave.’
After a ridiculous amount of time spent, I did finally figure everything out. I have DSD256 and all is good. The Airlens does make a difference.
For anyone who stumbles upon this and is curious . . . . make sure your ‘Mode’ is set to “original format.” If using a PS Audio DAC, Airlens, or other device that streams native DSD, do (not) select DSD over DoP, and do not select any bit rates. When configuring the DLNA server via the Media Server setup, do select “Audiophile 24-bit.” Deselect all DSP boxes. With the Airlens itself, be sure the “native DSD” toggle is switched on (the ‘up’ position).
My pleasure, ‘Timequest’.
