Possibly April 10th was a suggestion not a commitment?
Itâs there now! V2.5.0 and FW 208
https://cdn.shopify.com/s/files/1/0672/2283/1394/files/DirectStream_DAC_Mk2_v2.5.0.zip?v=1681247175
Is your I2S configured âcorrectlyâ? If not, all 0âs looks like all 1âs and hence the bottom bits arenât zeros for RedbookâŠ
I think Barry meant to add a note that some updates of options might not preserve the settings you used to have. I donât know the details of this update, but itâs likely that some (or many?) had combinations of options that didnât get set correctly. Sometimes thatâs obvious, e.g. the volume getting fixed to one value, sometimes a little less obvious like the maximum volume getting set to 0.
Hi Ted, is the wifi update option enabled in the latest firmware?
No. Thatâs scheduled for the next UI update later this year.
The Stereo Bit Perfect test file is in the âTools and Guidesâ tab of the Downloads section of the Support menu on the main site.
I didnât change anything from the last version. Is it configurable now?
Yes. Navigate to Audio Input/I2S Polarity⊠I edited my previous reply to you a bit ago with a little more explanation, but some people will have some options not translated over correctly during an update.
Since we are doing two updates should there be only one file on the USB drive at a time and do two updates or is it safe to put both files on the same drive and update that way.
Put all the files in the root of the drive. Put it in DS and power cycle. (Rear switch) The power light will blink about 50 times and then it will reboot. Then go to system load FW and pick 208.
Itâs safe to have both there.
Okay. Thanks Ted and Jeff.
Another way to notice auto power on with the I2S inputs is the small pause when you change to an I2S input thatâs set to auto on.
Iâm impressed. Most features are working now. Good job!
