For those who play with fuses, have you found it worth putting better fuses in subs? I’m about to replace SR Blacks in a pair of ATC actives with Audio Magic Ultimate Beeswax SHD’s and also have a pair of JL Audio e-110 subs I’m about to set up. I’m wondering what others’ experience has been changing the fuses in subs, whether you’ve found it worthwhile or just a marginal improvement, if any. I expect the crossover will be at about 55 Hz. Thanks,
