hello all, i picked up a mini dsp umik microphone to use room eq wizard. not exactly sure how to go from laptop to either bhk pre or directstream dac. i thought there was a old post about this but could not find it. any advice and/or links would be appreciated. thanks
I went with a usb a to b cable from the DSDac.
Chain is this: a to b cable to DAC and to the laptop, umik mic to the laptop on another usb port. REW will detect. You need the proper data file for your microphone so the proper calibration file is in place.
any usb a to b? i have one for a printer but not sure if it should be audio specific?
anyone will do. Exactly what I used.
