I’m streaming Tidal hifi through Audirvana to my Stellar Gain Cell DAC and am converting all files to DSD 128.
What settings on my computer (PC, Windows 10) should I change to get the absolute best sound out of it? I’m eyeing a Sonore ultraRendu someday but for now I have to stick to my PC, so I’d like to know what changes I can make (if any) to maximize performance with what I’m stuck with.
Hardware is Lenovo Yoga 2 Pro, 8gb ram, Intel Core i7 @ 2.00GHz, 64 bit, 256ssd, 2 usb (1 3.0, 1 2.0), and I run it on wifi and leave the laptop plugged-in when I’m playing it.
UltraRendu is only a streamer, so you’d still need a source (server of some sort).
Yes DS Senior and Junior convert everything to 128DSD, but it’s done to improve internal processes. Converting takes more computer power and storage space.
Yes, I would use the ultra rendu to have a more ideal USB signal to my GCD instead of my pc as the direct USB source, but as it stands now using my pc as A USB source I’m wondering what settings I can use to make things sound better.
This is meant to reduce noise and processes in the ESS chip. DSD has a simpler path through the chip. PCM is converted to a multibit DSD format but has to go through more processes inside.
