I prefer just leaving my audio equipment powered on but im concerned if I do that it will damage the screen if the DSD…screen burn in.
Have been putting it in stand by mode.
Any info out there in leaving DSD powered on?
Thank you
You can use the “Dim” button on the remote control to blank the screen. It will come on momentarily when you press a button on the remote but then will go back to blank. You can get back to normal by pressing “ON”.
But standby is fine - the guts of the DAC are still on, it’s only the screen that’s off.
Thank you Ted
Loving the DAC and appreciate all your work
Thank You!
FWIW, my DSD Sr. DAC is several years old.
I leave it on all of the time with the screen turned off. So far, so good.
Cheers.
Scott
Thank you
Yup, same here. Unit on, screen off. All good.
