M1200 making loud noise
This is the way.
Click on their name and you should see a blue rectangle offering Message - some members won’t accept messages. I’ll now try to message you with this reply text.
OK, RE, I think I see the problem. You are a new user and you are restricted as to what you can do for a while. Our Moderator, Elk, knows the rules, I don’t know them. Hopefully someone will explain things more clearly than I can. I believe i managed to message you (if so you will see a number on your green R (probably top right of your screen) and if you click on that you should be able to read my message, i think. You’ll need to be patient.
I have upgraded your user status. You should be able to message now. (New users cannot send messages.)
