Matching sound color between components and speakers
As I understand, PS Audio will produce new Speakers.
Does PS Audio match the sound color between their components and their new speakers ?
Thanks
The speakers will be voiced using the range of PSAudio gear but it would make sense to see how it sounds with other manufacturers amps and preamps. Hopefully no surprises that way.
Thanks!
Not to mention the space/room you setup the speakers will have a significant impact on their and the system color.
