MConnect or MControl for my iPhone....,
…and New DSD SR with Bridge II
I have downloaded them both but not sure which and I will set up SR w/Bridge II in the next couple weeks.
MControl is better if you are using Tidal and want to stream MQA. Otherwise they are very similar in my experience.
I will use it for Tidal so MControl sounds like the way to go.
Hi Rob, I use MControl, but have noticed on certain tracks in Tidal that the music stutters. Let me know if this happens to you. Thanks
