Does anyone have an idea what would case a ever so slight interruption of a track when using the Direct Stream DAC?
I suspect the source. With what are you feeding the DS?
Bluesound using Wireworld coax. It’s worked flawlessly until I recently moved. I will check connections.
I rebooted the DS and the Bluesound. Things are working fine now.
Very good.
