Sounds right. If you get SR fuses, Blue or Orange, go at least the next amperage up, about 25%, because they are prone to blow at spec. The Orange is especially good sounding, but many who went for spec value have experienced blown fuses. The alternative I went for before the Orange because I couldn’t stand the Blue was the Audio Magic Ultimate beeswax fuse (can be used at spec). I used one successfully in my DSD (now sold) and still have one in a P15. The Orange is better and while not cheap, it’s much less $$ than the AM. The newer AM Ultimate Premier is, well, I found the construction unstable (separate thread under this topic).
