Confused reading through all the “I have no cover art” threads, and have tried what seems to have solved the problem for others (insert blank SD card). On my unit, playing ROON over USB, I get no cover art. Is there some setting on the unit itself I need to do, or should it just come up automatically? etc. Sorry for being such a DS noob, much to learn.
Tbh I don’t care all that much, but concerned it’s not working since the unit is brand new. Have latest OS.
If you are playing Roon via USB that would suggest that you have another device in front of the DAC and you don’t have the Bridge II? Is that correct? If that is the case you cannot expect to get cover art that way.
