New high end PS DAC in the works
I just site here and waiting patiently for a new DirectStream DAC. The current one is to old and I am hoping for some of the experience building the new super dac will be used in building a new DS.
Also the network bridge and touch screen could use an update
Welcome, Martin!
What do you mean, the current DSD is too old?
I guess that MAQ chips and FPGA’s are cheaper and much faster today. The touch display could also really need an update.
It’s a computer and computers get outdated really fast.
But! it’s a great dac💪
If I remember correctly Ted Smith has said that the current FPGA in the DSD still has some resource available for further updates and that he has identified a few areas he feels that could give potential improvements and also that maybe some of the experience he has gained writing the code for the ‘super’ DAC might be transferable to the DSD.
Given this situation I’m very happy to continue with the old hardware that is the DSD. Judging by reviews the DSD continues to be up with the best on sound quality.
What would you do to the display?
I do not like touch displays, but find the DSD’s display works fine and does what is needed.
I can’t speak to PS Audio’s release schedule, but at some point there will probably be a DS replacement. I wouldn’t hazard a guess about features outside of the FPGA, but since the TSS will have an updated display I’d suspect that any new DS like DACs would too (tho not necessarily the same new display.)
Since the TSS uses an Artix 7 FPGA. I’d guess that any new DS DAC would use either that one or a little brother - for the kind of math and connectivity that the DS needs the Artix is best 7 series Xilinx FPGA to use.
FWIW The DS doesn’t really need a newer FPGA. If you were hoping that a newer DS could be cheaper than the old because of newer FPGA tech, well that difference is a small part of the overall cost. (Tho more speed isn’t really needed, having a little more RAM inside the FPGA could be useful.)
This sounds as if currently, improvements that really make a meaningful difference need HW measures like in the TSS while most of minor noticeable improvements could possibly be realized by firmware updates.
That would be fine. No need on my side for a different chassis with slightly better sound and a few thousand $ spent :wink:
Me too. I do appreciate that PS Audio puts so much effort into constantly improving their product via software updates, long after its initial release. However, the current DirectStream DAC is from 2014 and I am sure, that in the meantime, there are a lot of things which could be improved on the HW side as well. I am not going to spend 20K for a TSS Obsidian, as this device will not fit my budget. The DS however would match my budget, but I am not spending this amount of money for a 6 year old HW… So I am waiting for a successor of the DS.
The thing is, the traditional view of hardware getting out of date doesn’t really apply to FPGA designed kit as this gets updated with each release. I guess what psychologically makes it look old is only the casing styling.
I had a Junior, and now a Senior… I loved the Junior’s knob… I really hate the touchscreen… just awful. I feel like I am paying money for gimmicks.
Give me knobs and buttons. I had a club, I know how to smash things… I like a club.
Peace,
Bruce in Philly
But still: 6 years (design probably 7-8 years). I don’t say this product is outdated HW, but it is my philosophy that I don’t invest in HW of that age. Also, I don’t like the touchscreen implementation. Nothing against a good touch screen (like Naim Unity Atom or NAD M10), but the current DS touchscreen is not my thing.
I was wondering when might a new DSS software be coming?
I’ve been working on it for a while, but I wouldn’t count on it for a while longer.
Thank you Ted. I appreciate that you answered the question. I am so used to companies being shady about updates. Meanwhile Windom is no slouch at all. It is nipping on the heels of the best DAC currently made.
I did have a question for you. My screen is non responsive to touch. They fixed it Four times. I think once you said it might just be my bodies charge? My phone and tablets work fine though. Do you have any idea how I could troubleshoot it? It is out of warranty now. It does not work with an eraser either though. I know my way around electronics. Thank you
And it looks like mine went dark last night, is yours dark or just unresponsive ?
Have you recalibrated it?
No didn’t know abt that, will try, Thks.
Ted, that restored the display but I didn’t have to do the four corner touch, pls explain what that does and I don’t understand where I get the sequence from.
The four corner touch sequence calibrates the sensitivity of the screen to touch: e.g. how hard you have to press. (And a side effect of doing the corners out of order is that the screen may end up upside down, etc. :slight_smile: ) Sorry that sequence isn’t spelled out better, I believe it’s upper left, upper right, lower left and then lower right.
Thanks
