New Network Switch: LHY AS-6
… and so it begins
Ok, I just started listening on the SW10. Took me only 1 track… it’s good…
Since this is the AS6 thread, I will move further comments here:
Forgive me if I’ve missed this, but has anyone compared the AS-6 to the SW-8?
At least on the SW10-Pro if you use a Finisar 1318 BTL into the SFP data side, a Finisar 1475 BTL will output data to a streamer from the isolated side SFP.
At least to my Rose RSA 130.
I remembered the currently unused LHY SW6 switch in the cupboard, and how good it had been before being usurped by the even better AS6. I also remembered I have a Y power cable somewhere. Not ideal, but I don’t have another separate power run from the regenerator to my pre-station to the left of the main system. OK, let’s scratch that itch with double stacking.
About 10 mins is all it took to hook up the SW6 as the 1st stage switch, a short jumper Cat6 ethernet from SW6 to AS6, and flick the router Xangsane cable over from AS6 to SW6. Four Black Ravioli Big Pads between the two. No need to reboot anything, the Rendu remained happy with the temporary loss of networking.
I am hearing a lower noise floor. From this rises more soundstage ambience and lots of tiny cues, detail hidden deep in the mix. The overall presentation is calmer yet highly detailed. Note decay is the best yet, an outcome of such a low noise floor (for instance, the opening of London Grammar - Hell to the Liars). Glare is down (I noticed this in particular when playing Sheryl Crow - Home).
I thought I had lost dynamics due to this calmness, but no way after listening to Roy Gaines - Stormy Monday Blues.
A fantastic couple of hours’ experimentation.
Nice tower, but not sure about the doorstops, here in Europe they are filled with magnetic scrap
Hi Olly, just a newbe here, I just order the LHY AS8 Pro, this unit will be placed between my router and my Eversolo T8. The AS8Pro wil replace my TP-link, :-), connecting the AS8P with 1318, Corning Fiber and 1318 into the T8. When you talk about “the 1475 on the audio site” You are talking about the transciever inside the youre LHY? or the last transciever in the chain? In the last situation I dont know if it will be compatible with the T8..
1475 BCV intern audioside AS8, IMO that works best with the standard LHY SFP in the dataside.
I did not like the 1318 in any position of the AS8, but in the end you will have to experiment a bit yourself, every system is different.
I only use the AS8 internal optical break, rest is ethernet cable
Hi Olly, just a newbe here, I just order the LHY AS8 Pro, this unit will be placed between my router and my Eversolo T8. The AS8Pro wil replace my TP-link, :-), connecting the AS8P with 1318, Corning Fiber and 1318 into the T8. When you talk about “the 1475 on the audio site” You are talking about the transciever inside youre LHY? or the last transciever in the chain? In the last situation I dont know if it will be compatible with the T8..
Thx for the feedback,
Hi Olly, just to be clear… I keep on the inside the stock SFP on the dataside, and a 1475 on the audio side.
and On the outside of the AS8P, isolated out with the 1475, Corning fiber and 1475 into my Eversolo T8? This wil be the better set up? Or just isolated out with a good utp kabel? To the T8?
Hope I got it right now….thx
I also use the 1475 transceiver on the audio side (only works on Audio side) inside my LHY SW-10Pro. It is basically an improved version of AS8P.
In my system I preferred stock transceivers over 1318 as well as Optospan on both ends. However, 1475 sounds a little better to me.
Has anyone used the Finisar FTLX1475D3BTL 10GB FSP+ module in the AS6 or SW6 network switch? Does it work properly?
Looking for LHY SW6
220 volts. Max 350 euro
I have upgraded recently from SW-10 to SW-10 Pro - had Alvin make it with Clock IN as I have a Mutec Ref10 SE120 master clock - Only 4 days in - sounds good - nice upgrade.
Congrats!
It is good to hear the improvement is worthwhile. I really like mine.
I just received AS-6 Pro today - SW-10 Pro a week ago - running FTLX1475D3BCL between both - running great - sounds good so far but a few weeks of burn in to go…
Interesting since these two switches are using the same casing and similar design. I wonder if they sound similar in your system too.
There’s an AS-6 Pro? I thought there’s was only an 8 and a 10. Wait. I’m thinking of the Pro+. Sorry.
The AS-6 Pro just came out recently.
I’m happy with my AS-6, picked up a couple weeks before the pro version was announced. It’s been a nice step up from the SW-8
Just installed it - also changed from 1G Optospans in SW-6 to AS-6 Pro and 10G FTLX1475D3BCL‘s - Sound is smoother - maybe too smooth - but can’t make any judgements yet only been 2hrs lol. AS-6 Pro and SSFP’s need to burn in - Not an initial BIG Improvement like SW-10 pro was.
Okay, I did not know about AS-6 Pro, and I was thinking about SW-8 Pro that is similar to SW-10 Pro. There are too many of them. :laughing:
