I want to give everyone a clear picture of where things stand with the auto room EQ feature on the Foundry F12, particularly on Android.
The F12’s app includes both manual and automatic room EQ functionality. On iOS, the auto room EQ can use your phone’s built-in microphone, so it’s ready to go out of the box. On Android, a separate measurement microphone is currently required. The reason comes down to the Android ecosystem itself — there’s enormous variability across Android devices in how their microphones are implemented. Unit-to-unit consistency, automatic gain control behavior, noise suppression algorithms, and other onboard audio processing all vary widely from manufacturer to manufacturer and even model to model. That makes the built-in mics on Android devices too unpredictable for the kind of accurate acoustic measurement this feature requires. Apple’s tighter hardware control makes the iPhone’s built-in mic reliable enough to work for this purpose.
We’re still making a final decision internally on how to handle this — including whether it makes sense to keep this feature in the Android app at all — so I’d hold off on purchasing any microphones for now.
I also want to be straightforward about my broader take on auto room EQ in a subwoofer specifically. When this kind of feature lives in a source component or an integrated amp, it can correct the response of your entire system — that can be very useful. In a standalone subwoofer, though, it can only correct the subwoofer’s own response. It can’t account for how your main speakers and sub interact with each other in-room, which is often where the real problems live. So while it’s a nice bonus on iOS where the phone mic makes it essentially free, I’m not sure it’s worth the cost of a dedicated mic for everyone.
On the mic itself: the measurement mic sold by Platin Audio (the Danish OEM behind the auto room EQ and wireless functionality we’re using) is the recommended option if you do go that route. You may see the same mic resold under other names — Audiart, Buchardt Audio, etc. — but they’re all the same microphone hardware.
If you’re the type who really wants to dig in and get the best possible result, here’s my #1 suggestion: pick up a USB measurement microphone for your laptop and use free software like REW (Room EQ Wizard). That will let you take full-room measurements and then dial in the F12’s manual EQ, phase, delay, and low-pass crossover controls with a level of precision and system awareness that auto room EQ in a sub alone simply can’t match.
We have another product in development built on the same DSP platform with this same manual and auto room EQ functionality, so we’re working through these decisions carefully to make sure we’re adding real value and not just checking a feature box. More to come.
