Next DSD firmware update in 2020 or 2021?
Hi @tedsmith some of my friends own a few 24/384 albums (such as this one from NativeDSD) that play fine on their lower-priced DACs from Chinese companies such as SMSL and Topping. Having upgraded their amps and speakers, they are now in the market for much better DACs.
The local PS Audio dealer is a good friend and I’d like to help him sell. My friends are considering the DS but I understand the new firmware won’t be able to decode 24/384. What’s a simple “layman’s terms” way to explain to them why?
In the early releases of the DS everything was upsampled to the minimum multiple of both 176.4kHz and 192kHz, 28.224MHz. 384kHz doesn’t divide into 28.224MHz evenly.
Later when I changed the internal processing to upsample to 56.448MHz tho 384kHz does divide into 56.448MHz evenly I would need a quality filter to upsample 384kHz. It wasn’t a problem when I couldn’t upsample 384kHz and when I could in principle I couldn’t see myself degrading the sound quality of all of the other PCM upsampling just to add 384kHz upsampling.
There are more resources in the DS Mk II and if it doesn’t do 384kHz in the first release the second software release will support it.
When should we clear our calendars for the next trip up the mountaintop?
It’s scheduled for a mid April release. Stay tuned.
:+1: :musical_score: :notes: :grin:
WAAAAAH SO EXCITTTEEED (body apparently seems unclear. Forum doesn’t not understand YAAAS)
I recently added a Sonore Reference Rendu SE Optical. Best my system has ever heard. Sort of scary real.
That’s like two weeks from now, according to my calendar. You are dreaming, Sir Paul!
Please also test it with Bridge this time, so it’s no cause for a redo.
The team is working very hard on the new OS and we are making massive progress. Just as Paul stated, 2 weeks seems about right unless we discover some bugs.
You guys are going to love this OS. Ted has done it again, folks.
What I want to know is what’s the difference between an Analog Engineer and a Senior Analog Engineer? Do the Analog Engineers only work on RCA connections and the Senior move up to XLR? :wink:
It has to be close! Can we start a countdown to launch time?
Yaaaaaas please
Will the DSD firmware upgrade be available for purchase on SD card? I ask as my MacBook Pro just died and it’s replacement, MacBook Air, has no means to readily use SD cards. Argh! :nauseated_face:
Contact PS Audio support, they do keep a stock of compatible SD cards with the latest software on them.
Weapon of choice:
Anker 2-in-1 USB 3.0 SD Card Reader for SDXC, SDHC, SD, MMC, RS-MMC, Micro SDXC, Micro SD, Micro SDHC Card and UHS-I Cards
https://www.amazon.com/dp/B006T9B6R2/ref=cm_sw_r_em_apa_glt_fabc_8YW7QEJVFFPSC36PBN93
Leatherman version incoming, but it is nice to have options.
https://www.amazon.com/gp/product/B07ZDF65J6/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Yes! eight days to go. I bought the XS4400 mod, but I am hesitating to do the soldering. Hopefully the next-windom will give a lot of new discoveries in sound so that I can wait with the mod a couple of months!
Wait error :smiley:
Up, up in the Hill. Waiting for last Mountain Top. Ready to go next Week? Waiting for Sunlight …
