As promised, here’s the link to download 6115, the latest firmware we’ve all been gushing about.
Instructions are included. Basically, download the ZIP file.
UNZIP the file. Copy the UNZIPPED files on to a blank SD card. Place the card upside down (gold pins facing up) into the SD card slot on the rear of DirectStream (or a PWD with a DirectStream kit installed).
Power cycle DirectStream. Turn the unit off via the rear power switch, then turn back on.
The front panel logo light should be blinking if everything is loading properly.
Remove the SD card when the unit’s fully booted up.
Changes:
Raised the input filter's bandwidth from 40kHz to 80kHz
Added support for DXD 352kHz
Fixed a problem with long coax using S/PDIF
Lowered jitter
Fixed the balance control issue some users found
Improved the responsiveness of the volume control
Let us know what you think and why. Give things time to settle in once you change.
Paul McGowan said
It is essentially the same, cleaned up and all put together. I gave the beta testers a simpler version but the same from a sonic standpoint.
I reckon this is the same build, or is it recompiled compared with the beta version (SAA problem)?
This is embarrassing to admit, but I do not know how to download, unzip and then transfer a file to an sd card. Will this update be available to purchase already loaded on an sd card? Thanks.
No, it’s the same build, absolutely. The builds all sound different, as you know, so Arnie and I spent all that time culling through the builds to make sure we got the best and that it beat the older one. It is identical to the build the Beta testers heard.
We can walk you through it… what kind of computer do you have?
Hi Paul
Can you please make the beta version available on the beta page with download link
Thanks
Johno
I’d prefer not to. It can be confusing to people when we have too many versions floating around and our director of engineering asked me not to. The FPGA and PIC firmware are identical copies of what the beta guys got. No difference at all. The only thing changed are the version numbers so we can keep things straight.
I’ve noted when I copied and pasted the 6 firmware files from the download (excluding the instructions sheet from the files I copied onto my SD card) that almost all of the files when I pasted them into the SD card are larger file sizes than the download shows. Is that normal?
