It’s a bug in Pike’s Peak. CD’s with preemphasis cause it. Sorry about that. I don’t know if PS Audio will be releasing a patch (considering the work to retest the sound quality of a release.)
The PWT is good about informing the DS about preemphasis, if you rip the CD the preemphasis indicator will probably be dropped on the floor and the CD will play (tho with way too much HF loudness, some of us don’t find that to be a problem anymore )
Also foobar2000 and JRiver can be set up to do the deemphasis with appropriately tagged files, tho I’ve never pushed it thru so I can’t personally help on how to do it.
Not easily - we’d have to license it from Microsoft and they release it as software (at least the last time I checked.) I don’t know if there are near enough FPGA resources left to implement it. Apparently some of the HDCD decoders that are in players like JRiver, foobar2000, etc. only implement a subset of the HDCD features, whether that’s an indication that only implementing some features is good enough I don’t know, but I don’t usually do things 1/2 way
I think there’s a way to get WMP to decode HDCD streams to 24bit streams.
If you use dBpoweramp to rip it can also take care of HDCD encoded disks. Unfortunately I found this out after my HDCD disks had all been ripped with EAC - before dBpoweramp was even born.
tony, you can use dBpoweramp batch converter to decode your HDCD files (I rip HDCD discs in dBpoweramp with and without the HDCD plug-in and have subsequently converted some of the 16-bit rips to HDCD that way). The encoding is probably still there on your EAC rips.
I believe the HDCD plug-in used by dBpoweramp was hacked out of WMP. I also understand it does the half-assed version of the decoding. Typical Microsoft.
Thanks Steve, but now I’d have to go back and find all those ripped HDCD tracks! If there was a way to search and identify through my NAS it’d be a lot easier!
There is that. It doesn’t help that the HDCD logo does not always appear on the packaging. I picked up four CDs from the same artist last week and two of them turned out to be HDCD. I only discovered that after ripping. I use the HDCD plug-in by default (it doesn’t do anything to non-HDCD tracks) and dBpoweramp tells you afterwards if HDCD encoding was detected.
I sometimes wonder if they’ve done anything other than lower the peaks by 6 dB. I typically set dBpoweramp to add the 6 dB back and have yet to notice any clipping or other distortion and when I look at files where I left the volume as is using Audacity and similar programs there doesn’t appear to be anything above -6 dB. That may just reflect my particular selection of HDCD discs. The files do seem to sound better with the decoding but I have no idea what is really going on with the HDCD encoding and decoding.
