I haven’t been able to do any critical listening in quite some time because I’ve had my apartment torn up with a project which has now come to a close.
I’m noticing that the sound goes in and out of a muffled vs clear sound and that one channel is weak. When I bypass the DS and go right into my amp from my CD player, everything sounds fine. (Running Pikes, btw)
If you haven’t yet, you might try turning the DS off (for just a little) and back on. Then (if you haven’t yet) you might try going back to 1.2.1, then back to Peak. Channels reversed says that the FPGA needs it’s nose blown. Why this is happening now I don’t know, has the temperature in your listing room changed quite a bit since the last time you listened?
Ok, re-installed 1.2.1, and then upgraded to PikesPeak. Right channel still muffled and channels swapped. Went back to 1.2.1 and muffling is reduced but not fully restored, and channels are straight.
