No native x selection on PWD mkll
I just purchased a factory refurbished pwd mkll , I have hooked to a pwt via I2s . when scrolling through sample options I have native but not native X . am I missing something. it sounds great through native but I would like all the options . any thoughts?
What firmware version are you on?
November 4
It says 3.0.4 , Thanks
That sounds right. Can you reach out to support@psaudio.com or call us 800 PSAUDIO and speak with a tech?
will do, Thank you for your time.
told the new software does not include the Native x as a label , but when you scroll past Native, you are indeed in Native X, I guess Im going with that. thanks
