Hi guys, just bought a pristine Nuwave DSD DAC but when it arrived it´s a 230V unit and I just got 120V in here.
Can it be reconfigured ?
If so, how ?
Thank you in advance.
Mauricio
If so, how ?
Mauricio
I do not think there is a way to do so yourself, but contact PS Audio and ask.
Hi @Elk
Just did.
But someone in the forums may have had this expericne before and answer faster, so the post.
Really hearthbroken here ![]()
I hope someone can help.
I’m going to check if it’s an easy adjustment in the field. Either one of my team members or myself will send you an email next week.
Hey, thank you @jamesh
So you know I am an electronics tech.
Never worked professionaly with, but I know my way around a recap or a small mod.
But do not want to try and open the dac if there is nothing to be done.
And CONGRATULATIONS on PSAudio products and tech support.
You guys ROCK !!!
If someone else has this same question, there is NO way to reconfigure the Nuwave DSD, since every odel, 120V, 230V, 100V, uses a bespoke power transformer.
I had to return mine.
