Owners of acoustic suspension speakers, and especially subwoofers, should periodically check the tightness of all fasteners. I was listening to some orchestral film score music by Hans Zimmer and heard a rattling sound which I discovered was coming from one of my subwoofers. In loosening the screws to pull the drivers out I found some were very loose. The drivers seemed fine and I was able to reproduce the rattle operating the drivers outside of the sealed enclosure. The rattle sound is the voice coil bottoming out when the air spring is not present to control it. Reassembling the speaker and tightening all fasteners, including the control panel mounting screws, fixed the problem. The subs were in use over ten years.
An annual regimen
This was a recommendation for almost all speakers many years ago, but I believe construction techniques have changed such that the drivers and maybe screws are glued in place. I had this experience with my now 30+ year old Vandersteen 2Ci. Vandersteen glues all drivers in place and according to Richard the screws are there to hold the driver while the glue cures. I had to replace one driver a few years back and the screws were all firmly in place and I had to gently pry the driver loose.
Now, having said that, has anyone accessed the drivers on the PS FR speakers? I want to say they also glue the drivers in place but can’t positively say so. I understand the front panel comes off to access the fasteners, but I’m not going there until I get confirmation there is something to be gained.
Ironically, I discovered loose woofer screws in my speakers years ago. Vandersteen 2ci.
As I recall Richard said you don’t even need the screws after the adhesive cures. Not sure I would go that far but given how difficult it is to remove the sock and replace it I wouldn’t tell Vandersteen owners to worry about the screws unless you hear some odd rattling. I know some of the drivers can need repair, I did that with a mid-woofer, but loose screws were not the issue.
Just checked the screws on my SVS sub driver and found each needed a bit of snugging, but one was quite loose. Thanks for the tip!
“Mr Wilson” left me a 15 in-lb torque wrench when they came to set up my speakers. That’s not very much force.
Yes. Less force than one might think is what is typically used on driver mounting screws.
My old speakers had hundreds of screws. Whenever I clean the shelves I checked the screws too. Now I can’t find any screws on the woofers of FR30. So, I clean the speakers when I clean the shelves. Ain’t got nothing more to do with them![]()
