Hi, i do have a P10 and it is really good (second hand).
But if i run tube amps with it, there are clicks from time to time. Is this normal? Is there a way to improve this?
Thanks
Oliver
Thanks
Oliver
The P10 will click occasionally if if switches into quick protection mode. That is likely normal behavior. How much power are you drawing from it?
Thanks Paul for quick answer!
Not that much. If i drive my MC 452 there is no problem but with my jadis ja 30 it clicks about once an hour. Not that much but quite loud…
Thanks Oliver
Ok, that’s fine, perfectly normal.
